Question about Whirlpool LER2614JQ Electric Dryer
My Dryer won't heat up
I cleaned the lint, and checked the breakers and the clothes are still damp. Where do I gp to check the heating element. Is there something else I can do?
  • katha70 Mar 27, 2009
    i have changed heating element and thermal fuse. Now my next will be the Thermostat. If that isn't the problem what else can it be?
  • 447 Answers
You will need an ohmmeter to check the element and the hi limit thermostat and the non resetable thermal fuse. These are all axcessed through the rear panel if the dryer.
Posted on Nov 17, 2007
The dryer is not get hot. It take 2or 3 times ti dry the clothes
You might want to take a flashlight and check the vent and duct from the outside in. Lint will build up in the duct and vent over time. When you turn on the dryer with wet clothes in it, the lint will get damp quickly and it will dry out quickly too which make the dryer cycle shorter but not long enough to dry the clothes. Clean the vent and duct regularly and that should take care of your problem. You can buy brushes for doing this and they are not costly.
Jan 04, 2015 | Frigidaire Dryers
WHIRLPOOL DUET DRYER-Line clogged with wet lint from daughter air drying all of her delicate heat shrinking clothing. Dryer quit heating all at once that is when I discovered all of the wet lint in the...
if your dryer does not seem to be drying the wet clothes, first check that it is generating heat. If not, check the vent to make sure it is clear.
If the dryer runs but fails to heat clothing, check the circuit breaker. Most dryers use so much electricity that their functions are divided between two breakers. If one has been tripped, that may be why the heating elements aren't functioning. If the dryer still isn't heating, unplug it and pull it away from the wall. There's a service access panel on the back that should be pried free. Inside, you'll find a small black strip of plastic with two blue wires attached. This is the heating fuse. A replacement part can be had for around $15, and takes a little less than 1 minute to swap out. It's unlikely that the heating element itself, which consists of a few metal coils, is broken. If the dryer still won't heat, you're better off getting a replacement dryer than repairing the old one
Dec 08, 2011 | Whirlpool Dryers
Whirlpool Cabrio dryer temperature won't get hot? What causes this problem?
Runs but will not heat
1.loose wiring----check terminals & wiring
2.defective centrifugal switch in motor---replace switch ( check linkage to motor)
3.defective timer---replace heat element---replace heat element
5..defective operating thermostat---test thermostat, replace if defective or it's pulley loose on shaft---tighten set screw
7.incorrect heat or timer settings---reset timer
8.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
9.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 25, 2011 | Dryers
How do replace heating element in dryer
Things You'll Need:
* Volt meter
* Clean cloths
* Waste bin
* Replacement fuse (optional)
1. Secure the power cord in the Frigidaire dryer as well as the power outlet if the dryer does not start. Replace the fuse or reset the circuit breaker if necessary.
2. Check the fuse if there is power but no heat, as dryers need two fuses in order to operate properly. Replace the fuse if necessary. Select heated cycles if items are wet and cold after drying.
3. Open the dryer door and slide out the lint screen if the dryer seems to be taking a long time to operate. Clean off the lint and return the lint screen to the unit. Use a volt meter to check the power outlet for proper electricity, which should be 240 volts or more. Clean the exhaust hood outside the home and straighten the exhaust vent if bent.
4. Keep the load size medium and distribute pieces evenly inside the drum if items are wrinkled or damp. Increase drying time or temperature as necessary.
5. Check pockets for hard objects before putting pieces in the dryer, as items can create scratches or chips inside the drum and cause a clinking noise during use.
6. Contact Frigidaire for assistance if the problem continues.
Feb 24, 2011 | Frigidaire Electric Dryer
Bought dryer In October 2007. Now the auto-dry cycle is not doing the job. Clothes are still quite damp when cycle shuts off. The lint bucket is not full and we cleaned out area leading to it along...
You may need to reset the breaker for the heating elements or clean and check the continuity contacts. Go to This forum will work you through your problem
Sep 28, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Clothes still damp
have you checked the dryer vent,wall vent lint trap for cloggs,if clogged it will hold the damp hot air in the dryer much longer and add to your drying time-mike
May 29, 2009 | Dryers
My dryer runs but there is no heat to dry the clothes.
any heat at all? clogged vent pipe number one issue(if some heat is present) check 220 rec for 220! could be bad breaker motor will turn on 110 but needs 220 for heat....then go for element
Mar 13, 2009 | Dryers
Dryer not heating every cycle
A fellow once told me to do the simple things first.  Is the filter and the area where the filter goes in completely clear of lint?  Is the outlet discharging air in large or reduced amounts?  Make sure all is clean and flowing alot of air.  Oh, and check this before replacing other parts....turn both breakers off and then back on.  You may be running on 110 volts which will cause half of some heat elements from working at all or from working at full capacity.  If you've still got a problem and the clothes have been spun to mild dampness by your washer, you may need either a new element or new thermostat.
Nov 15, 2008 | Whirlpool LER5636P Electric Dryer
Maytag compact dryer low heat doesnot dry. works for hrs clothes still damp.
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 02, 2008 | Maytag MDE2400AYW Neptune Electric Dryer
Whirlpool LER2614JQ Electric Dryer Logo
154 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
