Question about Maytag Electronic Portable Air Conditioner Heat
It blows cool air for up to three minutes, and then the air turns warm.
    Champion:
  • 233 Answers
Sounds like a control problem, sensor if it is digital control, thermostat if it is analog, verify with the power off and an ohmeter
Posted on Jul 15, 2009
My EverStart portable air conditioning unit
sounds like you need to wash your condenser coil. Sounds like your compressor is kicking out on high head pressure. Once it cools off it starts cooling again take it out and give it a bath don't get the electric wet.
Sep 12, 2014 | Heating & Cooling
Air conditioner is blowing slightly warm air and not cooling when it is turned on
If after a few minutes it is still warm to hot air, try recharging the cooling system. Parts stores sell kits with instructions on how to do this.
Aug 28, 2011 | 1992 Honda Accord
Heating unit blows warm air then turns to cold air
it sounds like unit could be kicking out the low pressure switch or if it is a electric furnace it could be the sequincers
Jan 11, 2010 | Ruud UBHC Air Conditioner
MY 1998 FOR TARUS HEATER WILL NOT WORK.WAS DRIVING
It is most probably the problem with blend door or blend door actuator. But just in case I would suggest to follow the entire procedure:
First you have to identify what causes the problem.
To do this you have to:
1) When engine is cold check the level of coolant. If it is low fill it up.
2) Start engine and check if engine reaches regular temperature. If your engine is not heated enough it means your thermostat does not work properly and should be replaced
3) If engine temperature is normal, then check the temperature of pipes that go to/from heater core. These pipes are located up the fire wall (easier access is from the passenger side). If pipe/pipes are cold (even engine is warm) it means you heater core is plugged and should be flushed. Keep in mind, flushing the whole cooling system is different from flushing heater core.
4) If pipe/pipes are hot/warm, turn off the fan, switch controller to the hot position, wait for 3-4 minutes and turn on the fan. Note if the cold air blows first or warm air blows first but it cools down in 5-10 seconds. If the air blows cold than it is most probably the problem with blend door or blend door actuator.
5) If air blows warm first and then cools down, then while running engine and remaining the transmission in PARKING position, press on the gas pedal until your engine reaches 3,000 RPM. Check if your heater blows warm/hot air. If it does, then your water pump does not work properly and should be replaced. If the air still cold, I would suggest flushing the heater core.
Oct 17, 2009 | 1998 Ford Taurus
Heater not working
2) Start engine and check if engine reaches regular temperature. If your engine is not heated enough it means your thermostat does not work properly and should be replaced.
No cool air. blowing warm air
is breaker for condenser tripped---has it been running before -----is fan on outdoor ubnit running?
Jul 02, 2009 | Amana Heating & Cooling
Bryant Legacy Line air conditioning not blowing cool air..
Your outdoor condenser is in heat mode. Check the wires on the thermostat. Sounds like a small wiring problem and nothing else. Good luck. Please keep me posted as to you progress.
Apr 27, 2009 | Bryant 462AJC021BA Air Conditioner
My AC is not cooling the air
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, it is not blowing cool air after you emptied the tank.
Turn the unit off and unplug it for 5 minutes.............
Then back in with the plug and turn it on max cool.
Give it 5 or 10 minutes to get cold, and we will see if this procedure has reset the system.
Then get back to me and let me know it's working!
How old is the unit?
Please remember to leave a rating before you go!
Thank you Huuum
Aug 04, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Will not cool properly.
You have either a faulty thermostat, dirty condenser and evaporator or a faulty run capacitor. Need to service soon before the compressor is damaged. Sea Breeze
Jul 31, 2008 | Kenmore 75101 Wall/Window Air Conditioner
Maytag Electronic Portable Air Conditioner Heat Logo
270 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
