Question about Ertl 1/16 Ford 8N Tractor With Wagon
In 3rd gear the front wheels shake on 8N ford Tractor
In 3rd gear the Front wheels shakes...What can I do to fix this
  • 491 Answers
The quick easy answer is put your feet on the steering shafts just ahead of your feet when sitting on the tractor when driving at speeds causing the shimmy.This is what most people do.
The longer answer is a new or rebuilt steering box or possibly adjustment.
Some (most) boxes have play that cannot be adjusted tight even with a rebuild.
Posted on Aug 25, 2009
Shaking in front end.at about 2nd and 3rd gear, doesnt idle, dont know if its had an alignment on tires but need to know what the shaking could be.U joint?ball joint? Need answers please help!!
THE NOT IDLE AND THE FRONT END SHAKING I BELIEVE ARE 2 DIFFERENT PROBLEMS. IF YOU CAN GIVE ME A LITTLE MORE INFO, YEAR, MAKE, MODEL, ENGINE. SIZE, MANUAL OR AUTOMATIC TRANS, I WILL DO MY BEST TO HELP YOU
Dec 18, 2014 | Cars & Trucks
Wiring a selonoid
http://www.ntractorclub.com/
The link above is just one of a dozen or more very helpful websites for Ford 8n tractors.
The original 8n tractor had a six volt battery with positive ground (this is different than most automobiles that have a negative ground). The starter solenoid is energized via the ignition switch and the large starter button in front of the gear shift, the small wires going to the solenoid energize a coil which "pulls in" and completes a circuit that then provides 6 volts directly to the starter motor through a large, heavy gauge wire. The smaller wires connect to the two terminals on the top of the solenoid and the heavy wire goes to the larger post on the solenoid and originates from the negative post of the battery... Hope this helps. There are many, many schematics and pictures available on the "net" The Ford 8n community is very large and extremely helpful....Good Luck
Apr 11, 2014 | Ford 8N Tractor
Steering shakes at low and high speeds and pulls to the right
If it only does it when you are using the brakes, I would check the brakes on both sides.
If it does it without using the brakes, I would look for a bad tire on the front. One of the tires could have a broken belt inside the tread.
Could also be a bad wheel bearing on the front.
Sep 11, 2012 | 1997 Chrysler Sebring
Ford Focus shakes above 67 mph.
bad/ or out of ballance tires or a bent wheel
Jun 15, 2012 | 2009 Ford Focus
1999 Ford Taurus, steering wheel shakes when driving due to front passanger side tire movement/problem. The tires have been rotated and still problem from that area. What could it be?
Usually a steering wheel shake is a bad tire. Any chance you have 2 bad tires on the car? Only a front tire will make the steering wheel shake.
Aug 25, 2011 | 1999 Ford Taurus
Front end shakes when braking
will try to help. when front wheels shake while applying brakes and you can feel shake in steering wheel, front brakes and rotors need replacement.rotors are warped,if you replace front brake pads, it will return[shaking when you apply brakes] suggest that you replace front rotors[both] replace [both]front brake pads. cost? i would charge [brake pads cost $55.00] labor,$60.00] total $115.00 thank you for choosing fixya.com
Dec 04, 2010 | 1998 Ford Windstar
When stoping steering wheel shakes
Have your front brake rotor's cut or replace, there warp that why it shakes at stops.If your going to have them cut make sure they mic them, if to thin, they will warp again.
Jul 23, 2010 | 2001 Ford Taurus
1995 Ford Taurus shaking when hitting the brakes
sounds like spindle/axle may be bent!
Oct 04, 2009 | 1995 Ford Taurus
Ertl 1/16 Ford 8N Tractor With Wagon Logo
469 people viewed this question
Top Ertl Toys Experts
Colin Stickland
Colin Stickland
Ron Knox
Ron Knox
Level 1 Expert
Are you an Ertl Toy Expert? Answer questions, earn points and help others
