I have a Hyvision (Magnavision) 192 LCD monitor/TV (i'm using it as a monitor) and the picture wouldn't come back on after a reboot. It does come up from right to the left, great picture, then goes blank. If I turn it off and back on, the same thing happens but it won't stay on. I figured it was the power supply, but when I went down to replace it, they tested the voltage on it and said it was good. I can't find anyone to repair it, so thought I would give it a shot, it seem like it must be a capacitor or something, almost like when the battery is not fully charged in the car. I don't know where to get a schematic of the innerds of the monitor and I don't know how to unlock it, any ideas? Thanks, Sandy
    President:
  • 2,777 Answers
Very strange, sounds almost like it could be a few things. First off, you say you're using it as a monitor, you mean a PC monitor? Does the actual power to the unit go off or does the picture just go out and the lights / tv stays on?
Thanks, let me know and we can try to figure out if it's fixable.
Tim
Posted on Jul 14, 2009
Pix on screen for abour 3 seconds then goes away----green powere lamp flashes???? whats going on???
Did you try this monitor with another PC yet and also check the VGA cable?
Most failure in the LCD monitors are due to bad DC filter caps as you can see in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/
You may want to learn more here in details if you are going to do DIY repair.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 02, 2011 | MegaVision Hyvision Megavision 191 19"...
I try to power up the hyvision mv220 monitor and my display shows dim for a second then goes to blank.
Look for bad DC filter caps first, then the backlight inverter circuits.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Aug 22, 2010 | MegaVision MV220 Monitor
My HyVision LCD TV Picture disappears after a few seconds
It seems that the "backlight" has gone bad. "Backlight" is the device that allows to see the picture in an LCD TV, when they are about to go bad the symptom that you describe is very usual. It depends on the tv manufacturers and model to expect how long the "backlight" is going to last in a tv.You can shop around for a replacement part and try to do it yourself or take it to an especialized technician. Good luck..
Jan 03, 2010 | MegaVision Hyvision Megavision 191 19"...
After power outages my monitor will not come back on right away. It only blinks in the background.
GET YOURSELF UR UPS,IT WILL AVOID YOUR PC FROM CRASHING,AND YOU WILL NEED A NEW MONITOR WITHIN 6 MONTHS,ITS REACHING THE END OF ITS LIFE SPAN
Jul 04, 2009 | MegaVision Hyvision MV177 17" LCD Monitor
My monitor jitters
when u power up press F8 key then go to enable vga mode then set resolution to 1024*768 thne check .
Nov 14, 2008 | MegaVision Hyvision MV177 17" LCD Monitor
Picture won't stay on.
The problem is with the backlight inverter driver. It thinks that one of the CFL lamps is bad. I fixed mine by opening it up and cutting a track in the inverter board (with the power off!!). But you need to be a bit of a geek to undertake this fix. I you want more details email me at lmann1952@yahoo.com
Jul 24, 2008 | MegaVision Hyvision MV177 17" LCD Monitor
Picture but no sound on Hyvision LCD monitor MV190
I had the same problem. The speakers are mounted below the the LCD Monitor. There is no internal connection between the speakers and the TV Audio. There should have been a short patch cord in your box having one jack on one end and two wires with mono jacks on the other. Plug the stereo jack into the audio out on the monitor and then plug the other jacks into the left and right side of the speakers (the wires should be marked L and R). If you cannot find the jack, I'm sure that you can find one on line or get one from Radio Shack.
Nov 07, 2007 | Gateway FPD2275W LCD Monitor
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
