Question about Kenmore Dryers
Kenmore dryer keeps making a ringing sound when dryer is on.
  • Kenmore Master
  • 19,396 Answers
If the nois is kind of rattling noise, then it is usually caused by objects (coins etc.) trapped between inner and outer drum. If instead is an high pitched noise that gets louder when the machine spins faster, then it is usually a bad drum bearing.
Posted on Jul 14, 2009
I have a kenmore 70 series dryer that overheats in evrery cycle even in the air dry cycle. Another problem is that when the cycle is done the tumbler cuts off but the timer keeps running keeping the...
Sounds like you may have two problems but the main problem might be that the element may be broken and one side is grounded, The switch on the motor may also be stuck in the on position as well.
Feb 26, 2011 | Kenmore 62802 Electric Dryer
I have a Kenmore Elite dryer. It is not drying the clothes properly. It takes a lot longer to dry the clothes. One time it dries fast the next time it takes forever. Any ideas??
it sounds like your dryer stat real name t.o.c. you will need a engerneer to do this the job should cost no more then £40 pound ring a round for a call out the cheapperst is not all ways the best ok so make sure you ring 4 to 5 guys just tell them the problem and they should say the same if they dont get back to me and i will try for you see if i can get some one to help you in your area ok
Feb 03, 2011 | Kenmore Elite HE4 Electric Dryer
My kenmore dryer wan start ,when i push the koob it sound like it will start but it dont if i keep pushing it it stop making noise
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 20, 2010 | Kenmore Dryers
Kenmore dryer making a weird noise
sounds like a bad drum wheel,it won't do anything bad you can keep using it or replace the wheel-mike
May 07, 2010 | Kenmore 62602 Electric Dryer
Found a large gray felt ring dryer - now it rattles
reattached the felt ring correctly around the drum to make it run quite again
Apr 26, 2010 | Kenmore HE5
My kenmore dryer just stopped working. the timer
the timer has internal cog teeth with works with an ecentric cam to keep the timer operating. the cam is working if ticking although a tooth appears to be broken keeping the timer to advance on its own
Mar 13, 2010 | Kenmore 63942 Dryer
Kenmore electric dryer series 70, on the inside of my dryer there is a plastic white ring that is cracked and brittle, clothes get stuck on this ring and tear, can I replace this white ring?
Yes, you can replace that ring.
I believe you have a front loading machine, if so then you will need to remove the front of the machine to expose the ring, drum and belt.
Try this website and see if they can supply the part you need.
Good luck, I hope this helped
http://www.partsselect.com/
Oct 03, 2009 | Kenmore 73952 Gas Dryer
Kenmore Elite dryer heats but does not dry
Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
Mar 12, 2009 | Kenmore Dryers
Dryer making very loud noise.
We had the exact same noise all of a sudden start coming from our 2 year old dryer. We checked everything, rollers, pulleys, motors, etc. I was certain it was coming from the upper left. Finally we found a loose screw had fallen into the front felt ring. Problem solved!
Good luck.
Jan 20, 2008 | Kenmore 63942 Dryer
Dryers Logo
147 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
