Question about Yamaha Audio Players & Recorders
My yamaha em1400 produces no sound. everything is
My yamaha em1400 produces no sound. everything is hooked up one second sound then no sound wha happen
No sounds from my yamaha HTR6030 Display is OK. All function keys working.Relay clicks. But no sounds.
Try connecting different sources to different inputs or fm source if nathing produces sound I would recommend to have it check by a tecnitian
Aug 19, 2016 | Yamaha Audio Players & Recorders
Why does yamaha waverunner fx cruiser ho not run in lake but will run hooked to water hose
Sounds like you have a bad stator. It may be producing enough spark to start the motor, but under a load (as in the water) it simply can not supply the amount of spark needed. Sometimes when a stator is tested on a ohms meter it may test good, but still be defective do to the load it will come in contact with when put in the water.
Jun 29, 2014 | Yamaha 12V Air Pump
I have a phono preamp hooked up to my Yamaha receiver for a turntable. My tall speaker tipped over and knicked the receiver and now my turntable will not produce any sound. Could this have blown the phon...
Let's figure out which hardware is failing. Connect the phono preamp to the CD or tuner input to see if it works there. It should. If it does, your receiver is at fault. Did the front panel controls get damaged?
How did the turntable fare in this accident? As a basic test of its ability to produce sound, hook it directly to the CD input and raise the volume slowly while playing an LP. If it's alive you'll hear a very weak, tinny sound, but I assume you know that or you wouldn't have a phono preamp in the first place and would probably be asking why the TT sounds so poor. :-)
Jan 19, 2010 | Audio Players & Recorders
No sound from cable via V665 receiver
Can't pass HDMI thru this or any other receiver with version 1.1,1.2,1.2a,or 1.2b. HDMI is riddled with issues! it's not Yamaha, it's HDMI. The current version 1.3b is working "so far" If your receiver is still under warranty, Yamaha will update the software and hardware at N/C. If it's out of warranty, Run HDMI directly from source to TV and Audio to your receiver via optical or digital coaxial. For more info than you can process, google "HDMI forums" and there are over 73,000 posts/sites/etc. If you need further info, post a comment and I will be glad to help.
Aug 22, 2009 | Yamaha RX-V463 Receiver
No sounds coming out of subwoofers
CHECK INSIDE UR SUBWOOFER BOX ...
Apr 11, 2009 | Pyle PLAM2300 Car Amp
Components aren't powering up
Sounds like the board is not receiving power. Check that the power connectors from the psu to the motherboard are securely in place, or else try another psu
Mar 22, 2009 | Gigabyte Computers & Internet
Sony amp 1000w
Check the wiring of the speakers (both inside the box and between the box and the amp). It sounds like one speaker is wired incorrectly at one connection point.
Sep 09, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
I just bought the yamaha htr 6140 and i am haveing a problem hooking everything up.i getm sound no pic or pic no sound or pic and sound from direct tv hd box and then the dvd player wont have sound or...
http://audio.manualsonline.com/regman/exit/ct?url=aHR0cDovL3d3dy55YW1haGEuY2EvYXYvUERGcy9SZWNlaXZlcnMvMjAwOF9Nb2RlbHMvSFRSNjE0MF9NYW51YWwucGRm&idDeviceType=650&idMfg=55&idProduct=569172
Jun 27, 2008 | Yamaha Audio Players & Recorders
89 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
