Question about Hoover U5172900 Fold Away Widepath Bagless Upright Vacuum
Why are new belts breaking immediately?
I was given a Hoover widepath fold away. Why are belts breaking immediately? They break at the "driver" --motor?-- part, not on the brush. They melt. There is only a peg to wrap the belt around -- is there supposed to be some sort of wheel over the peg that drives the belt? Or can the brush be bad, becoming difficult to turn, thus locking down the belt which then burns and breaks - i did smell burn rubber!
    President:
  • 1,124 Answers
Could be the brush has resistance..
While the new belt is in place - spin the brush by hand.. The brush should spin reasonably freely..
If not - take the brush out and inspect it.. Be sure the ends are not jammed and you can snin them easily.. If not - replace the brush..
PS - the belt goes in one way.. If inside-out - it will not last as long..
Directions on packageing..
Hope this helps !!
rate mehood ;o)
Posted on Jul 14, 2009
Hi guys i had the same problem as what dude is saying, the belt has a hard time moving the brush. I fixed my problem today so i decided to post and let yall know how.
The belt has only a small metal rod that comes out of the motor, and on the other side of the belt its the brush and the part that touches the belt is shiny, and looked like it has been slipping there too.
I solved this problem by using a hack saw, and roughing up the metal rod where the belt connects to the motor. And on the other end i roughed up the plastic on the brush using the same hacksaw. Vacuumed the entire house, and my car. My vacuum has a new lease on life i hope the same for anyone else with the same problem.
Posted on Apr 08, 2010
I keep having to replace the belt on my Widepath Hoover Temp. Last time, the belt wasn't broken but had come off the spool. How can I secure the vacuum belt and/or stop it breaking? Thanks for any...
First be sure you have the correct belt for the machine. The current belt may be stretched, but not broken. The correct belt is # 38528033, or in a package of two, the package # is 40201160. When you have the agitator out of the vacuum, stand it on end and make sure it turns easily. If it does not spin freely, there may be hair or string in the bearings which will need to be cleaned out.
Jun 21, 2011 | Hoover Tempo Widepath Upright Vacuum -...
The brush underneath isn't turning!!!
Check the belt. Make sure it's attached properly. Replace if broken or worn.
Sep 01, 2010 | Hoover U5172900 Fold Away Widepath Bagless...
Hoover Tempo Widepath - propellor not working
If you are refering to the roller underneath, the belt nees to be replaced. Simply remove 4 bottom screws and then the roller, Place new belt on roller and thenon motor shaft, pull belt with the roller to install in position and install bottom plate.
May 02, 2010 | Hoover Tempo Widepath Upright Vacuum -...
I have a Hoover fold away and the floor cleaner doesn't work only the attachments are working.
The reason for this would most likely be a blockage in the bottom of the foot of the machine. could also be a bad belt. Check or change the belt and look for obstructions.
Apr 21, 2010 | Hoover U5172900 Fold Away Widepath Bagless...
Brush on hoover wide path does not spin around.
remove the bottom cover and check the drive belt.if belt is ok then your brush motor could be bad.
Jan 29, 2010 | Hoover U5172900 Fold Away Widepath Bagless...
I CAN'T FIGURE OUT HOW TO REPLACE THE BELT ON MY FOLD AWAY!!!! PLEASE HELP
The manual for this vacuum can be found at: http://www.manualnguide.com/dl/13985/
Refer to page 9 for instructions and visuals on how to replace the belt.
Apr 14, 2009 | Hoover U5172900 Fold Away Widepath Bagless...
Hoover Empower Widepath Vacuum Doesn't ****
This model requires the lower end of the hose to be installed into the base unit to pick up the dirt. If it is properly installed, I would check the belt and also look for a blockage. The normal life span of a belt is about 9-12 months. your belt # 40201190 2 pk
Mar 11, 2009 | Hoover U5172900 Fold Away Widepath Bagless...
How do I replace the belt on my hoover wide path fold away vacuum
on this model there will also be 2 more screws at the top near the back on each side. the hood will come off. there will also be a cover over the roller, remove this with 3 screws, this will expose the area of the belt.
Feb 26, 2009 | Hoover U5172900 Fold Away Widepath Bagless...
Hoover U5172900 Fold Away Widepath Bagless Upright Vacuum Logo
212 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
