Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
Sharp aquios 32"
Power led keeps flashing
  • Killahill Nov 19, 2007
    The power will not turn on - power light just keeps flashing red
  • vk6ws Dec 01, 2007
    did not fix problem
Unplug the tv from the power outlet, wait until the light stops flashing then plug it back in. works for me.
the flashing light means that your tv needs to be serviced, if its still under warranty you shouldnt have to pay for this.
-w
Posted on Nov 28, 2007
Is my sharp aquios 60 tv led equipped with blue tooth capability?.
Your owners manual will tell you. Barring that, google the make and model#. Different models, different features. good luck.
Feb 25, 2016 | Sharp Aquos Televison & Video
Sharp aquios tv turns on but nothing on screen
Hi Richard,
Please consult some local TV tech or the service center. There is nothing you can do about it yourself.
May 24, 2015 | Sharp Aquos Televison & Video
SHARP AQUIOS QUATTRON LC-60LE810UN
the motherboard needs replaced, due to the onboard voltage regulator is out.
Oct 29, 2017 | Sharp Aquos Televison & Video
60" sharp aquos power indicator is flashing one short flash and one long flash and keeps repeating the sequence
POWER LIGHT FLASHES ONE SHORT AND ONE LONG FLASH.
What is the problem? THE PROBLEM IS THAT ONE OF THE LED's STRIPS IS BAD!
SHARP AQUOS LC60LE810UN RESET INSTRUCTIONS
1)Plug in TV to electric current First then wait until LED start flashing.
2)Press Volume DOWN [ - ] HOLD BUTTON.
3)Press Channel UP [ ^ ] HOLD BUTTON.
4)Press Power [ (') ] HOLD ALL three buttons until LED stops flashing and then release.
    ┬ĚThis will reset the TV in order to fix the problem.
    ┬ĚTHE FIX IS TO REPLACE ONE OF THE LED's. You need to open the back of the TV and you will also need to remove the front cover and panel to get to the LEDs. The TV will need to be placed facedown and on the backside. This is a 2 person job to turn the TV on its sides. Be careful with the white computer connectors (wide white strip) at the base of the TV where the TV stand sits. You will need to disconnect this in order to get to the LED's.
    Once you have the LED's exposed, you will need to unplug one by one by placing the new strip next to it until the unit turns on. You will have to use the RESET procedure above if the Power lite flashes. The Power lite MUST BE ON SOLID - no blinking in order to test the strips. The LED's will flash, but still one of them will be burned. Even if you stare and all the strip light-up, you will still need to check one-by-one!
    Once the TV lights up, your face will also light up with joy! Put everything back together and you are set. If you need the complete instructions which come from Sharp as to how to disassemble the unit, please send me an e-mail to LGTR61@YAHOO.ES. Please note I don't check this address daily, so a few days wait may take for you to receive the instructions.
    Where can you buy the LED's - try searching Yahoo.com or Google.com for resellers.
    SHARP AQUOS LC60LE810UN LCD STRIP INFORMATION
    LONG STRIP (49 LED's)
    FRONT SIDE BACK SIDE RL 94v-0
    E329419
    1029
    LFa
    Sn-Ag-Cu
    Ps-1
    K4458TP
    4458ZZ
    0921FM
    104863
    ee03A
    SHORT STRIP (30 LED's)
    RL 94v-0
    E329419
    1025 LFa
    Sn-Ag-Cu
    Ps-1
    K4459TP
    4459ZZ
    0714FM
    302213
    Mm05A
Apr 10, 2013 | Sharp LC60LE810UN 60 in. LCD TV
My tv doesnt show any images and the panel has the light of fopc on
Common problems on Sharp LCD tvs as tv it is agings,tv Power LED and OPC LED,LEDS lights flashes happen to mine Sharp tv many times and i had it two years,do this many times,tries to turn on the tv.By trying pushes the power button the remote again if OPC LED and power LED,LEDS lights flashes together.Everytimes the OPC LED and power LED lights flashes,just push the power switch on the tv remote and wait for the tv main Tuner signal board to kick in the backlight to light up tv to work.Have to do this like three or four times before the power supply board to kick it in to make Tuner signal to work.If u require to this more than 5 or 6 times the main tv Tuner signal board it is shorting out and beyond trying to kick in by the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
May 31, 2011 | Sharp LC-32SB24U 32 in. LCD TV
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
MY Sharp LC46D62U wont turn on
Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Mar 13, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
405 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
