My machine is second hand. No bobbin came with it. I found a clear canister - filled with thread, but I'm having trouble sewing. Should there have been a bobbin case???
Depends on your machine. Some machines don't have bobbins, but majority of them have bobbins. The other thing is that different machines take different bobbins, so you need to make sure you have the correct bobbin for your machine.
You might want to search the internet for an owner's manual for your machine:
Manufacturer + Model + the word "Manual"
The bobbin is the bit that you put the thread on
it then drops /fits in the bobbin case
when you put the bobbin in the case you have to pull the thread around until you find a slot and pull the thread around under a flat spring
then you drop the lot into a bobbin case carrier
go google and type in-- user manual for( make and model) sewing machine and that will give you a site with a pdf version down load on how to basically set up the machine to sew
Other than that take it to a service center for any type of sewing machine and they will probably have any missing parts or be able to get the parts if required
