Kenmore Elite top loader makes loud knocking sound when spinning
I have a kenmore elite oasis top load washer model number 110 27087602 model. During the spin cycle the washer will knock so hard it moves the machine out of position on the floor and will shut the machine down. I can reset it to spin cycle only only. Sometimes it will spin all the way through other times it will not. This is frustrating and I only had this machine for almost two years. It appears that the tub is out of balance or a spring is broken I can see through the glass top because it wobbles from side to side which causes the loud knocking sound. Thanks hope some one knows how to fix this problem I don't want to spend another $1000
  • 867 Answers
Sometimes the agitator gets loose, causing the drum to sway to far all over the place.make sure its tight , remove the softener dispenser (manual nut), then tighten the metal nut that holds the agitator down
Posted on Jul 14, 2009
Sounds like loose pieces clicking inside washer during spin cycle
Can you tell from the sound if the noise is near the bottom or not? The sound could be from something stuck in the pump. If you can post the whole model number, I can find more information..
Aug 06, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Loud noise during the spin cycle
Did you have an oil leak at the bottom of the washer? If yes, chances are your transmission oil leaked and your transmission needs changing or repairing.
Jan 15, 2014 | Kenmore Washing Machines
Kenmore oasis makes loud noise when spinning
You can check the shock absorbers, maybe is not in good conditions.
Dec 23, 2017 | Maytag LAT3600A Top Load Washer
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
Kenmore elite oasis top loader 27062
See the following Whirlpool / Kenmore service manual for the Whirlpool Cabrio washer. The Kenmore Oasis is basically the same.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Also see the Sears Parts site for your washer.
Enter the full (###.########) model number and you should see descriptions of the major components and parts lists.
May 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore Elite Oasis HE washer model #27092600. It is making a loud noise before and during most of the spin cycle when it is trying to drain. What would cause this. I have had this machine since...
Mine was making a high pitch sound, thought a rock got under drum.... now it stopped yesterday full of water ... and won't spin or drain. What can I do here at home to fix it?
Apr 04, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Noise during spin after changing clutch / kenmore elite washer
The clutch is likely failed again - or the coupling this time.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite shaking during spin cycle
Moved a Kenmore Elite and when we put it back in place it vibrates loudly. We tried leveling it and that has not worked. Any ideas?
Sep 27, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
1,198 people viewed this question
Top Washing Machines Experts
