You have to use the same type of light already in the circuit
If the lights are filament lights (bulbs) then halogen lights will work provided that the wattage is not higher than the existing bulbs
If they are then you will need to reduce the current flow through the circuit by installing relays so that the current is drawn directly from the battery
IF the circuit is not designed for LED lights then you will need to talk with an accredited auto electrician with experience in fitting LED lights so that the circuit is not comprised by the addition of the LED lights
