Question about GE WBVH6240F Front Load Washer
Tour rubber gasget leaking
We also have a tear in our front rubber gasget and would like to find instructions on how to replace
any help appreciated
Mitch
  • 92 Answers
Firstly,if it isnt a bad tear you could always try putting a patch on it ie a puncture oufit for a tyre this works as i have done this for a lot of young single mums who cant afford a new boot.but to replace a new one then you have to take the metal strip off around the boot wich you call gasket,once done this it lifts off with a lip all around it then just pulls out make sure when replacing that all the lip sits all around the drum.
Posted on Jul 15, 2009
My washer is leaking water after completing a cycle
Check the rubber bellow (gasket) around the door. This is the symptom of a door gasket that it starting to leak. Pull the rubber folds back and check the area where the gasket attaches to the wash tub. You may have a crack or tear.
or
The only way to determine where the leak is coming from is to remove the lower kick panel directly below the door. Remove the panel by removing the screws under the bottom front edge. With the screws removed, the panel will drop down, then off. If you prop the front feet up this will give you better access (a 2 x 4 works well).
With the panel removed inspect the rubber door bellow. If the front counterweight (gray concrete block on the front of the tub) is wet, the bellow is leaking. Pull the rubber folds back and look for any rips or tears. If the bellow requires replacing, or if you need to simply tighten the clamps, the following link will explain how:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
NOTE: Check the plastic dispenser hose on the left hand side of the bellow to ensure it is inserted all the way through the rubber to the flange joint. Sometimes this dispenser hose will slip behind the bellow and allow water to seep inside the cabinet of the washer.
Check the drain pump to ensure the filter cap is secure and not leaking. The pump is in the front directly below the wash tub. If the pump IS leaking, make sure the filter cap is tight and all hose clamps are snug. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
Check all hoses the run from the wash tub to the pump, and from the pump to the standpipe at the wall for any signs of cracks or tears.
If the leak is coming from the center portion under the tub, the tub seal is breached and needs to be replaced. This is not an easy repair and will require some extensive disassembly to repair. (Cross that hurdle when the time comes).
Any replacement parts you may need can be purchased at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. You can use any web source you like, but these I have found, offer great service with competitive pricing. Shop all of them for the best prices. Hopefully you won't need any parts.
Feb 10, 2011 | Washing Machines
It is leaking water between the motor and the impeller, I just installed it at the end of last season and it worked fine but when we opened our pool this week and turned it on, it started leaking. I...
Sounds like the seal is leaking, but in cold climates I'v seen the cases cracked from freezing. How much water is leaking and does the leaking get worse when the pump is running?
May 27, 2010 | A.O. Smith SQ1102 Pool Pump Motor
Leaking water under front edge of machine?
Open the door and gently pull on the grey rubber gasket and check all around it for holes / tears. There are three tiny holes in the 'wall' at the bottom that are supposed to be there, but you should not see any other tears. I just found a large tear on mine that causes leaks when I run very large loads. I am going to try to fix it with Gorilla Tape, otherwise I will probably have to buy the whole new gasket. It seems like it would be a real pain to replace!
Apr 30, 2010 | LG WM-2277HW Front Load Washer
A piece of the rubber has come off the inside of washer and water now leaks out,
Piece of rubber WHERE? If you are referring to the rubber bellow (door seal), they will wear out with age and may become mishapened from repeated pressure from the door being closed. Over time the bellow can stretch or develop rips and tears and begin to leak. If the bellow is leaking, or no longer providing a good seal, it must be replaced. This will cause water to puddle under the front of the washer and inside the cabinet. The following link explains how to access and replace one:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts can be purchased at any of the following websites:
repairclinic.com
All these sites are reputable and have great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If the model number is correct, the part number is 8182119.
If you are not referrig to the door bellow, or if you have questions about this repair, please post back and let me know. hope this helps you.
NOTE: If you leave the door OPEN between washes this will help prevent constant pressure on the door seal which can stretch it out of shape over time. It is also beneficial to allow the wash tub to air out to prevent mold and mildew from forming. In addition, overloading the washer can contribute to premature wear and tear on the bellow which can lead to rips, tears and possible dislodging from the bellow clamp seals. Always follow the manufacturer's recommendations for loading in your owner's manual.
Apr 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking in front of washer mainly from what seems to be the gasket around front of washer.
Either the rubber boot is damaged in some way, or the door is not locking tight enough. Thoroughly inspect the boot for tears or gouges in the rubber surface. Small imperfections can be repaired with silicon glue, but larger tears will require replacement of the boot--which can be done done through the door opening, but requires patience to do so. Inspect the door lock for damage or wear if the boot looks to be in good condition.
Oct 12, 2009 | LG WM2277H Front Load Washer
GE model number WCVH6600HWW with a huge tear
I have the same problem and I'm thinking of trying to replace the boot myself. I found this at ehow.com. The instructions and pictures seeem pretty good.
http://www.ehow.com/how_5651102_replace-front-load-washing-machine.html
Jun 04, 2009 | GE Energy Star WCVH6260F Front Load Washer
Leaking Washer
If it is leaking from the front you may have a tear on the rubber door seal feel around the seal for a hole or tear.You will need a tech if there is a tear just did 1 today not easy:)
Jun 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE3T washer leaking water
The rubber seal is called the "bellow". Replacements can be ordered on line at searspartsdirect.com, appliancepartspros.com, or repairclinic.com. All three sites offer great service, so shop around for the best prices.
For instructions on how to replace the bellow yourself, follow this link:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
This is not a difficult repair, but it can be a bit intimidating to a beginner. If you have questions along the way, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 31, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Front Loading Washing machine door gasget leaking
These arent terribly difficult with mechanical capabilities. The clamp which snugs the bellow to the tub (toward the inside) can be tricky. The front is snugged by a spring loaded cable. Also, take care to align the fill tube at approx. 10 oclock looking at it from the front. And make sure the fill tube is entirely through the hole in the new bellow. It can get frustrating but usually takes less than 30 min.
Nov 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE WBVH6240F Front Load Washer Logo
85 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
