Question about Grilling
Gas is not flowing to burners on my gas grill
There are a number of reasons why this might happen. I've noticed on the new style gas tanks you have to open the top valve on the tank very slowly in order for the gas to flow. Also, insects and spider webs get into the line causing a flow prolem. Your regulator might be defective or the burner itself might have moved from it's position where gas enters. Listen for the flow of gas amd be careful if you try to light it. Good luck!
Posted on Jul 21, 2009
My Uniflame grill may have a clog somewhere through the fuel delivery system, or at the the tank connection, how would I be able to find the culprit?
Hi boltbucrayfa...
I think your culprit is the gas regulator valve...
If it is not working properly then it will not deliver the proper amount of gas to the burners.
Check all your burners to make sure they are not plugged...
The when you are outside away from Flames and ignition sources.
Remove the hose from the grill...open the gas to the grill (you have the hose off the grill) and listen to the flow of gas...if it is very low then there is your problem.
You can shut off the flow of gas, then tap the gas regulator on the sides, top and bottom lightly with a hammer and then turn back on the gas to see if the gas flow increased...if it did, then shut off the gas and rehook up the gas line to the grill..and your good to go grilling again.
Some gas regulators have an adjustment under the removable cap.
If the gas flow did not increase, the replace the gas regulator
Please take time to rate me
Sep 26, 2011 | Uniflame FG2204C Grill
Gas will not flow to burner to light grill?
could be the reg on the tank , not working no flow of gas ,
May 15, 2010 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
1st of 3 burners will not light. The other two have gas flow.
blocked burner or gas injector or gas on off switch blocked
May 15, 2010 | Weber Genesis E-310 Gas Grill
The new style OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
Mar 28, 2010 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Have gas at inlet but no flow at burners
If your grill has a regulator on it and you get gas before the regulator, but not at the burners, then your regulator is probably bad. If there is no regulator, or you get gas flow after the regulator, then you may have a blockage in the orifice(s) in the valves or the venturis in the burners.
Dec 27, 2009 | Lynx L42PSR1N Gas Grill
I have a charbroil, advantage series grill. It isn't lighting.
How rusted are the burners? It is possible there is rusted metal blocking the gas ports. I don't have enough information from you regarding the problem...do you hear the gas flowing when you turn the burner open and the gas bottle is open?
Go to your user's manual, there should be an illustrated parts list. From there you can order new burners...you can also do this at Char-Broil's website.
Burner replacement is easy: take the grills out, then remove the flame tamers (the tent looking thing that sits over the burner to prevent flame-ups), the burners are screwed in to the grill at the back, remove the screws then grab the burner, pull towards the back of the grill and then up...this will disengage it from the gas valve in the front of the grill. Putting in a new one is the exact revers of this procedure...just make sure when you put the new ones in you make sure the burner's gas intake is connected to the valve at the front of the grill. Once done, you should be good to go.
Sep 07, 2009 | Grilling
Poor gas flow. Burners will not stay lit. Gas
Try taking a large hammer or set of vice grips and banging pretty heftily on the tubes feeding the burners. These are usually build ups of Carbon. If not, then make sure your connections are good (sort of move them around to see if they are loose), and make sure your propane is not getting too close to empty (you can shake it around and feel/hear the propane).
Aug 10, 2009 | Amana 5939 Grill
Gas flowing to burners 1 and 2 but not 3
there could be debris in the carryover tube..(the open channelled pipe that connects the three burners together) alignment is also critical,
Jul 12, 2009 | Weber Genesis Silver B Grill
Gas is not getting to the burners on my Sears Kenmore gas grill.
check if regulator fully screwed to tank, turn on tank,then last burner,should hear/smell gas. if not replace regulator
Jun 25, 2009 | Kenmore 16225 Grill
Jenn Air Grill - Gas flow from one valve
I have the same problem. The middle and the right burners will work, but if I light the left side (3rd burner) all 3 go out. pressure is reduced to zero.
Aug 30, 2008 | Grilling
Grilling Logo
316 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
