Question about Hotpoint First Edition FEW12 Front Load Washer
Does not appear to take in cold water.only hot.
    President:
  • 1,136 Answers
Hi, The first thing to check is the screen in the inlet valve. Remove the cold water hose and see if anything is plugging the screen.
If there are no restrictions, start the washer in cold cycle only and see if the inlet valve hums. When there is power to the valve, you should be able to hear it. If there is no noise, it will probably need changed. The sure way to tell of course is to check voltage to the valve for 120V. If it's not getting voltage, there is another issue.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 14, 2009
    Brigadier General:
  • 4,088 Answers
Turn cold supply faucet off, remove cold hose from washer (catch water in hose), and place hose end in bucket. Turn the cold water faucet on again--should have good supply of water. If not, check for plugged inlet screen at faucet end of hose. If everything is ok, then probable defective cold water solenoid valve inside machine. Check water inlet at machine to see if it has a screen that might be plugged.
What causes error code Hc?
This error code indicates that the cold and hot water inlet hoses are switched.
This code will appear at the end of the wash cycle to indicate that the cold and hot water inlet hoses are switched. If an error code does not appear, but you are experiencing poor wash performance, check to see if the inlet hoses are reversed.
May 12, 2015 | Washing Machines
Why is the hot water pipe dripping after tighening up.
First the is a hot and cold water pipe. To those are connected hot and cold water outlet bib valves to which are connected, respectively, hot and cold water hoses going to (or you could say, coming from) their respective connections to the washer. Correct this if I am wrong but, it appears you might be talking about those hose connections to the water spigots but calling them pipes, not hoses. If that is true, you contecture is correct: it is most typically a worn out hose washer or o-ring and replacing that item should correct any dripping. By sure the part is characterized for hot water.
Oct 28, 2014 | Washing Machines
I have a Heatslave 12/14 oil-fired combi boiler installed approx 8 years ago. A problem has just developed on the domestic hot water side. My local heating engineer has investigated but so far hasn't...
Symptoms sound like crossover might be part of problem:
Crossover is when cold water enters hot water line due to faulty plumbing part like check valve, mixing valve, or bad faucet cartridge.
http://waterheatertimer.org/Crossover.html
Jun 12, 2011 | Bosch Water Heaters
Hot water comes on but then runs cold after a minuate then goes hot again. The water appears to be hotter downstairs
If you have lukewarm water.. and at times it's hot.. then warm. or after running hot for a while and it cools.. chances are you have a cracked or failing dip tube.
The dip tube is just what it sounds like. a tube that delivers cold water to the bottom of the tank.. to mix with the hot water.. this keeps the hottest water at the top for faster delivery.
If this tube is cracked near the top.. or along it's length.. you may get some hot water.. then cold.. then warm..etc etc.
They are inexpensive to replace.. but as always exercise caution and follow proper procedure to relieve pressure, water supply and power/fuel before attempting a repair.
Generally this tube is inserted right where the cold water inlet pipe is on the heater.
A good plumber or water heater replacement or repair company could inspect fix and replace for a lot less than a new water heater.
Best of luck
Apr 10, 2011 | Heating & Cooling
We have a Westinghouse Laundromat 800 (7Kg)that overflows. It appears that the when it fills itself with water (hot or cold) it does not automatically close the valves(?). Can you please help. Thanks.
Hi just read your posting.Now try this.Select only cold water fill and start cycle,then when you hear water entering your machine turn the power off at the wall.The water should stop filling straight away.If it does try the same test on your hot water.If either of the valves are faulty it should continue to fill after you have turned the power off to the machine.Please reply and tell me if the hot or cold water did not stop or if they both stopped.Please try the test on hot and cold a couple of times to be sure.Looking forward to your reply.
Jun 27, 2010 | Washing Machines
Water Temperature is hot on all rinse cycles Water temperature on rinse on all modes is HOT.  Water is hooked up correctly (the delivery folks hooked it up when installing).  Steaming hot - too hot to...
if your gettig hot water on rinse.your fill hoses are not correct.rinse is only cold.switch the hoses.if that dosent solve the problem call for warrenty
Jan 03, 2009 | EuroTech EWF150 Front Load Washer
Cold water inlet not opening
Check the filter on the cold water inlet first to make sure it is not blocked. Next check the cold water solanoid. Take it out. Clean it, let it dry.
Jun 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
Water
you need a cold or hot water valve. one of them is not closing all the way after the cycle is done. turn off cold water at wall, if no water appears you know its the cold water valve. if water does apear you know its the hot water valve
Nov 16, 2007 | Bosch WFMC 3200 Front Load Washer
Hotpoint First Edition FEW12 Front Load Washer Logo
93 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
