Question about Panasonic KV-S1025C
No target device !! (id: 3056) Error: 11 This is the error window I receive after trying to scan papers to my machine. I downloaded the TWAIN driver but still cannot work the scanner.
  • 163 Answers
SOURCE: Inconsistent tif file creation with Panasonic KV-s7065c
pleaz oil the scanning lamp drive unit and clean the lamp
Posted on Sep 21, 2007
SOURCE: Remove paper from scanner
I have this same problem every time I unplug my Panasonic KV-2026C. I've lost the original disk with the utilities, and the Panasonic web site says, they only provide the disk with the original equipment. You know, I'll never buy another Panasonic product. But I'm usually able to get the ready light to come back on by doing the following. I use a clean cloth that is soaked in Rubbing Alcohol (not nail polish remover, but pure rubbing alcohol). I basically open up the back, and clean each roller. There are two green tabs at the top of the back of the scanner. These need to be opened up (be careful, because the parts sort of fall out if you're not careful, and they are difficult to re-assemble). Again, wipe everything down with the rubbing alcohol. Close up the upper tabs. Make sure you wipe down the glass slits on both the door (front-of-the-page scanning port) and on the unit itsel (back-of-the-page scanning port). Before you close up the back door, let it sit for about 5 minutes, allowing the rubbing alcohol to evaporate. I also connect the scanner to the laptop and get the "blip" sound from Windows to recognize the scanner. I don't know if that's important or not. Then I say a healthy prayer, plug it back in and shut the back door. If there is a god on duty that day, the ready light comes on, and stays on as long as I have the power connected. I just went through the process and it worked!!!! The minute the power is off, the error light stays on. Good luck, my friends! Joe Diehl, Seattle WA
Posted on Aug 10, 2008
SOURCE: KOdak 2500 D -- cannot find target device
Go to Kodak's website and download the scan verification tool (the SVT), and see what it tells you. I use the 2500D with an Adaptec 2940 SCSI controller, and a 50-50 pin SCSI Cable.  I use the twain driver from Kodak's website and paperport 9 software.  This combination seems to work.
Posted on Jan 30, 2009
prawinmv22
  • 106 Answers
SOURCE: the ready/error indicator is red... the error
hi....
I have this same problem every time.....first unplug it.....I use a clean cloth that is soaked in Rubbing Alcohol (not nail polish remover, but pure rubbing alcohol). I basically open up the back, and clean each roller. There are two green tabs at the top of the back of the scanner. These need to be opened up (be careful, because the parts sort of fall out if you're not careful, and they are difficult to re-assemble).
Posted on Jul 04, 2009
  • 16 Answers
SOURCE: Scanner No Paper Detected Error
There is a narrow FFC cable that connects the sensors between the hoppper assembly and the main scanner unit that may be loose. Check both ends. This cable can also develop small fractures over time. These fractures can cause the sensors to not be noticed by the scanner or give false info. The cable may need to be replaced.
Posted on Sep 08, 2009
Error 2148285
What driver are you using no twain suggests that the driver is not twain compliant. You may need to update the driver with the correct operating system like windows (whatever it is) or is it MAC OS .
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/fi-series.html
Apr 21, 2014 | Fujitsu Fi-4120c2
Canoscan Toolbox returns a TWAIN error with
maybe the software that you download is a 32 bit O.S only that's way it cos you and error. because your O.S
is not compatible to the software that you use. download a 64 bit driver twain
Mar 05, 2010 | Canon CanoScan 4200F Flatbed Scanner
Scanner twain driver will not install
Dear sir,I am sory for your problem.Please format your oparating system i mean you install new windows.some times optical driver did not read properly data cab file,So hardware driver is not support properly.Windows xp SP3 is not complite version some messing.
Thanks You are success
Tareq
Aug 27, 2009 | Epson Perfection V300 Film Flatbed Scanner
TWAIN Driver Error
If connected via USB, unplug cable and insert into another available port and error message should disappear.
Nov 14, 2008 | Fujitsu fi-5120C
Jul 14, 2008 | Kodak Digital Science 2500D Path-Through...
TWAIN error
Connect the scanner and re-install the driver. That should fix it
Jul 10, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Error message
What is your operating system?
If XP, check your device manager to see if the scanner is being recognized by XP.
What is your scanning software?
Try to use another scan program ( a free demo version should work fine.)
Are you using TWAIN or an ISIS driver? If it is a TWAIN driver, then any Photo editing program should be able to connect ( usuallly!?).
Jul 04, 2008 | Office Equipment & Supplies
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
Panasonic KV-S1025C Logo
3,492 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
