Question about Whirlpool Washing Machines
IT STOPS IN THE MIDDLE OF THE WASH AND RED BUTTON HILIGHTS SAYS CLEAN PUMP
  • Whirlpool Master
  • 3,361 Answers
Simple enough. Remove the access panel,unscrew the pump and clean out the lint. Re-install the pump screen and you should be fine.
If you have a model number and need more info let me know.
Posted on Jul 14, 2009
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
What would stop a bush a126q washing machine draining, it just stops in the middle of a wash cycle?
hi i have a BUSH A126Q model W/M .Spin and Drain dosnt work. I clean the FILTER but same problem. Error code is Err 03. The start light & program ready light is blinking when M/C go to spin / Drain.
Its looks pump dont work //////
Please advise me what to do ???????????
Thanks
Mar 19, 2011 | Washing Machines
Here again is my model and serial it stops in the middle of the cleaning cycle Kenmore 665.16773402 serial # ft0302854 Here is how I have been resetting the dishwasher. I hit the following sequence of...
Door latch.
Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options.
Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
Oct 06, 2010 | Dishwashers
Started to wash, then stopped. wont spin
turn water off and disconnect water hoses. there are small screens in water inlets where hoses attach. use a flat screw driver or something that will fit in the inlet to rake debris off of screens. if you cant get screens clean pull them out they are replacable.
Jan 09, 2010 | Whirlpool Washing Machines
Does not complete wash cycle. Machine cuts off in the wash cycle with the water still in the tub. I can re-start at the beginning, but it just stops in the middle of the wash cycle and I cannot get it to...
You need a new pump. When the pump is bad it won't drain the tub. It just stops after the wash cycle. They aren't to much of a pain to replace. Repair man will be about $200. Do it yourself about $65. Give Sears a call and they will give you the run down. Good luck. If you are going to do it yourself let me know and depending on the model I could give you step by step RR. Good luck. Regards.
Oct 19, 2009 | Washing Machines
Wash cycle stops, F21 error message appears
"F21" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. More than likely you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Sep 11, 2009 | Kenmore Elite HE5t Washer
My heater comes on but only runs for a short time then stops. It shows not problem code. The only thing that showed once was at the bottom of screen FL O & a service man above.
Go to a larger GFI breaker .for the heater element. Make sure the circulation pump is running and the pool is full of water. adjust the water temperature button to 100, the water level lever to middle, Check the ground conections for corosion, Did you servise the filter element and did the back wash regularly , check the presure at the pump gauge .Vitally
Jul 02, 2009 | Pool & Spa
Washing Machines Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
