Question about Plumbing
Meyer CT20 pump, 220volt seized (does not run)
Pump covered and stored outside in winter, but with plumbing anti-freeze in housing. Pump turned on in for irrigation and did not turn over. Circuit breaker tripped after 5 - 10 seconds. Heard a 'buzzing' sound - presumably motor was trying to turn over the pump.
I am mechanically inclined but need to find the most common problem and solution(s). Suspect pump has seized due to corrosion - can this be fixed or do I need a new pump and/or motor? Should the pump have been taken indoors for the winter?
  • Anonymous Mar 24, 2014
    My irrigation pump cast iron housing crack during one of the coldest winters in Ga. I bought it from Lowe's and it's outside there window to return. I wondering if the company can assist me in getting it replace.
  • 297 Answers
Yes it has seized,the brushes are most likely to far gone to fix.you need a new one.yes store inside in the winter months!
Posted on Jul 14, 2009
How to winterize Keystone 2013 Cougar 330RBK ~ we have no manual.
run the water out and put anti freeze in ,you will have to drain hot water tank and when all the water is out put anti freeze in the water tand and turn on pump and run all faulcets and make sure the hot water tank gets some.
Nov 13, 2016 | RVs
How to determine if your motor is seized? after putting water in the coolant during the winter?
Nick, put a small heater under hood of car for 3 to 4 hours, point it towards front of engine directing toward water pump location. After 3 to 4 hours try to turn engine over to see if it is seized.
Engine probably not seized, if coolant was not strong enough, frost plugs may have popped, which would be better then cracked engine block.
to show your appreciation press the helpful button and follow me on fixya for more tips and info.
Feb 15, 2016 | 2002 Volvo S60
I live in NC and have chosen NOT to close my ingroud pool. I leave my variable speed pump running continuously at a low speed. I'm worried about extended cold weather below freezing. Will incr
Even at low speed these pump move allot of water, I would feel better with the pump running on high. but most variable speed motors only run on high for a few hours and return to low speed. If you cant force the motor to run on high continuously, IF YOU can't run it on high= The wind chill is the concern, might I suggest covering the plumbing portion with a tarp, just do not cover the motor it needs air to cool the motor.
A $10 hot water heater blanket Google Search might work on your filter,and some plumbing insulation tape Google Search OR if it gets real cold you could build a temporary pump house out of say 2'' PVC and with 8 or more Concrete Blocks and some tie down straps to secure it down and cover the whole works with a tarp using some of the blocks to hold the tarp in place, this way the heat from the motor will keep it nice and warm inside your temporary pump shed, but this is only if you can't run the motor on HIGH continuously, low speed worries me with possible - minus 40 Degree temps.
also turn the pools jets up to keep the pools water from freezing up and turning into a skating rink.
IF you have a pump that only runs on high for a few hours you will need to set your alarm clock and get up and reset the pump to run on high again, just to be safe.
The pump creates heat by act of pumping water, so you have that on your side. ..keep us informed on your results as these variable speed pumps are fairly new to the market.
thanks .. Jay
Jan 07, 2015 | Pool & Spa
C48j2ec11c3
The pump should be installed inside an enclosure. If you live in an area which has freezing temperatures, the pump and all plumbing need to be protected from freeze ups.
May 11, 2014 | Plumbing
Winterize vcross 365 fifth wheel
I think you have posted this several times so I wanted to add this.
The best thing is to have a dealer do it. You need to know if you have by-pass kits installed, depending on what you have for storage tanks they need to be drained, RV non-toxic anti-freeze needs to be added to plumbing and flushed through, water lines should be blown out along with draining so if there is a place where the water was level it gets forced out.
Here is a quick info for a skyline, but it really depends on what you have for plumbing.
Purchase 4-6 gallons of RV approved, non-toxic anti-freeze.
2. Drain all tanks, fresh water and sewage tanks.
3. Turn water heater by-pass valves to by-pass position. (The by pass valves are located near the
water heater incoming lines - an access panel may have to be removed depending upon the
model.)
4. Drain water heater.
5. If installed, remove water filter from assembly and discard. Install diverter if included.
6. Pour an amount of RV non-toxic anti-freeze into the fresh water tank to fill the tank above
minimum water pump operating level. (Use of a long funnel may be helpful) Add more, if
necessary, during procedure.
7. Turn on pump switch and open the cold water side of all faucet fixtures. Leave open until the
anti-freeze comes out (generally, pink in color). Repeat for hot water side.
8. Flush toilet until anti-freeze begins to flow into the bowl and then pour one gallon of anti-freeze
down the toilet to winterize the black tank.
9. Pour anti-freeze down each shower/tub, lavatory sink, and kitchen sink to fill p-traps.
10. To winterize gray tank(s) pour one gallon down each related sink drain.
*****Now the best thing is to post a new post and see if someone has your manual to be exact.
But if you get no response, and refuse to let a dealer do it, you have a little bit of info to help you.
Sorry I couldn't find the exact method for your model.
Apr 09, 2013 | Sport & Outdoor - Others
Take apart rule pool cover pump
motor seized how over the winter the discharge hoses freezes thus no discharge pump burns out motor that is
Nov 07, 2012 | Rule 1800 H53SP-24 Swimming Pool Cover...
How to winterize my gas powered presserwasher
THEY SALE FUEL WINTERIZER SOLUTIONS AT ANY HARDWARE STORE AND AUTOMOTIVE PARTS STORE. AND YOU CAN PUT SOME ANTI FREEZE IN THE PUMP TO STOP IT FROM FREEZING AND CRACKING.
Dec 11, 2010 | Karcher K2.26 Electric Power Washer
How do I winterize the pump....how do I get anti-freeze into it
We don't recommend using anti-freeze, see attached link for the different options to winterize your pump
http://www.wmpcs.com/blog/?p=63
Oct 30, 2010 | Dewalt DPD3100 Gas Pressure Washer
F2 Error code beeping
your pump has seized.To check remove all the dishes followed by the grey dish wrack wedged in the bottom. Lift off the plastic spray arm to reveal a grey plastic ring around the outside of the stainless mesh, and you will also see the blue plastic impeller. Turn this anti clockwise and lift out the whole stainless mesh cover.
Then there is a brownish ring with the blue pump impeller on top. Turn this anticlockwise and the pump should lift straight up and out. My blue impeller had come off and lifted off with the brown ring leaving the rest of the pump stuck in the hole! I eventually managed to get it out without damaging the housing it fits into. Replace the motor/impeller unit and off you go.
May 01, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Have a large new house with lots of vinyl clad wood double hung windows on a lake temp today this am is 0 F we have a HRV system house temp is 66 downstairs and 58 upstairs heating with a heat pump and...
Really not efficent to run a heat pump at those temperatures. Below freezing is not good for the compressor in the outside unit. The humidity in the house with the low temp. is causing the condensation on the windows to freeze. Kinda like an air conditoner does in the summer without the freezing humid air from the house goes over the cold a/c coil and the moisture condensates on the coil running down to drain pan. raising the temp. in the house and lowering the humidity should help. I would also recommend running the electric heat in low outside teperatures.
Dec 17, 2009 | Aprilaire 600 Humidifier
Plumbing Logo
69 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
