Question about Toro Lawn Mower With Toro Power Tools
I have the Toro edger/trimmer combo - which way does the edger blade bolt turn - I tried counter-clock-wise it won't budge. Also how to the LOCK the blade from turning??
    Scholar:
  • 106 Answers
On blad removal the nut goes opposite to tighten, lefty tighty, righty loosen. Put a metal wrench or rod in between the blade and the guard to keep the blade from moving.
Posted on Apr 14, 2010
To change the blade which way does the nut turn to get it off? Clock wise or counter clock wise?
Most weed eaters are opposite to conventional thread. So they are CLOCKWISE to take off
Apr 30, 2016 | Weed Eater PE550 8-1/2-Inch 22cc 2-Cycle...
Replace blade
Usually, but not always, they turn clockwise so that the rotation does not unscrew the lock bolt or nut. If the lock bolt or nut is reverse thread, it probably turns counter-clockwise.
Consider including more details in your questions, it makes answering them specifically, easier.
Sep 08, 2014 | Garden
Trying to replace the blade on my Craftsman edger; the nut holding the blade won't budge - now I'm not sure which way to turn it to get the blade off!! Clockwise? Counter-clockwise? Thanks. Larry...
Take a little break and spray the shaft where the nut is on it with some PB Blaster or Liquid Wrench penetrating oil. Let it soak tonight and turn it off counter-clockwise tomorrow. If you can fit a good sized box wrench on in, turn the wrench down towards the ground and give it a few good whacks with a rubber mallet or hammer. Try not to strip the head of the locking nut.
Oct 29, 2010 | Craftsman Garden
Does the bolt on the blade come off counterclockwise or clockwise.
If you are facing the blade from where the bolt is, and the blade's normal operation is to turn counter-clockwise, then the bolt will loosen counter-clockwise. This is universally true for any blade which is held on by a center bolt (table saws, grinders, etc.) This is because the motor is turning the shaft counter-clockwise, and the resistance against the blade as it does it's work is clockwise - thus tightening the blade rather than loosening it. If the blade normally turns clockwise, then the bolt will loosen clockwise.
Jun 24, 2010 | Craftsman Garden
Can not remove the old blade
1. Unplug the saw.
2. Locate the blade lock button used to lock the motor shaft when changing a blade. For your saw, this button is usually located on the left side of the blade guard somewhere around the motor housing.
3. Push the button while rotating the blade until the button engages and the blade will no longer turn.
4. Use the wrench that came with the saw (or another wrench) to loosen and remove the blade bolt. For your saw the bolt should have standard right hand threads which means you loosen the bolt by turning it counter clock-wise.
5. Remove the old blade and replace it with a new blade of the same mounting type. Some blades have a round through hole and some blades have a diamond through hole.
6. Re-install the blade bolt and tighten clock-wise while holding the blade lock button down.
Oct 03, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Trying to change the blades on a yard machines MTD lawn tractor,bolts wont budge,do you turn clockwise or counter clockwise liken I have been trying to do to loosten the nets.
They turn off counter clockwise. Sometimes due to the heat they are subjected to, you may need to heat around them with a propane torch before trying to loosen them, or take it somewhere with an impact gun to take them off. Hope this helps...
Aug 29, 2009 | Garden
Trouble un-screwing edger blade bolt
It may have left handed threads and needs to be turned clockwise to unscrew. As for sharpening an edger blade...it won't cut any differently. That short blade, traveling that fast and rubbing against concrete is going to do it's job, sharpened or not.
Jun 20, 2009 | Garden
Trying to remove part that fits on motor shaft.
Grab the bottom of the motor shaft with a pliers and the plastic part will twist off by turning it counter clock wise.
Jun 19, 2009 | Toro& Electric String Trimmer
Toro Lawn Mower With Toro Power Tools Logo
218 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
