Question about Kitchen Appliances - Others
Motion Flood Lights blinking on and off repeatedly
I have motion sensor flood lights. The motion sensor is seperate from the light, so I can relocate it. Recently one of my sets of flood lights started blinking on and off without any detection. What could be doing this? Thanks.
SOURCE: outside wallmount motion sensor
try ebay
Posted on Aug 06, 2008
SOURCE: Heath Zenith #SL-5316 Motion detector light what are settings?
Go to http://www.heath-zenith.com/search.cgi (displays as HEATHCO webpage) and search for SL-5316 ... choose manual below.
See http://heath-zenith.hcents.com/data/manuals/595-5109-13.pdf
Thanks
Posted on Jun 16, 2009
  • 188 Answers
SOURCE: Have Cooper lighting outdoor motion detected flood
Sounds like the relay in motion sensor. Change the bulb. Rechargeable batteries are no good after 3-4 years also.
Posted on Jul 23, 2009
  • 113 Answers
SOURCE: we can't get the motion on our flood lights to
There are different selections on a flood light that you have to adjust. It is possible the you have it in test mode right now and when you flip the switch you are sending powering to the flood and it will stay on because it is in test mode. If it is not in test mode and you have it in the normal operation mode you may have the sensitivity set to high. If there are bushes near, running water, or anything that is moving quite a bit all the time it's going to stay on. Also, depending upon how old the flood is. It may simply need replacing. I would check the first two items and go from there. If you become completely stumped, a good electrician should be able to problem solve this very quickly. I have been on a few service calls where simply the flood was bad and needed to be replaced. I hope this helps.
Posted on Jul 31, 2009
SOURCE: my motion sensor stopped working--the lights are full on all day.
i have pir movement the problem is without movement its getting on
Posted on Sep 02, 2009
Defiant flood light 180 degree led: 1. Instruction manual says to put a maximum of one such light on a wall switch. Why can I not have 2? 2.it has photo sensor in addition to a motion sensor? Thx.
Maybe two light fixtures each with photo sensors and the lights being near each other, might trigger both sensors to react to each other and turn lights on and off rapidly.
Jul 09, 2016 | Home Security
After two weeks of working perfectly, why did they start to blink and stay on all day?
Sometimes, these fixtures "forget" what they were set up to do. You may have repeat the set up procedure to retrain it. Also, I have found that power interruptions such as a tripped breaker or power surges can cause memory loss.
Feb 10, 2016 | Defiant Flood Lights. 180 Degree Outdoor...
Why did my motion light stop working and the sensor light is blinking red?
Did you find out why?? I just purchased 2 of these and loved them as they worked for like a week and now both are not working however they are getting power as the red light comes on when there is motion...Please help if you know as I paid 110.00 each for these and I am confused how the bulbs could be blown?
Jun 02, 2014 | Defiant Flood Lights. 180 Degree Outdoor...
I have motion sensor flood lights that are not turning on. I put it on test & it does turn on. But when switched over to 1, 5 or ten minutes it won't turn on. The red light on the sensor does turn
April, you didn't mention whether you did the test at night. In addition to motion sensing, the flood light also detects darkness before allowing the bulbs to light up. If it is night, check also that some other light source is not illuminating the sensor. If so, that could fool the sensor into thinking it is daytime.
Mar 03, 2014 | Electrical Supplies
I HAVE A UTILITECH PRO 180 #0205881 AND IT BLINKS WHEN ITS ON
Usually when a motion sensor light blinks LED or otherwise it means that the motion sensor is shot. The light itself is most likely good and for whatever reason you got a bad sensor upon purchase.
Feb 21, 2014 | Utilitech Pro 180-Degree 2-Head LED...
Flood Lights. 180 Degree Motion Activated Solar Powered Floodlight -
Sounds like the batteries are not getting charged. Check to see if there was some packing material in place to keep the batteries disconnected for shipping.
Dec 05, 2013 | Cooper Lighting Flood Lights. 180 Degree...
My Utilitech Pro will come on, after a few seconds it will blink twice and then will not come on again for several days.
Sounds like the sensor has failed. The controls are supposed to be on the underside, and kept dry.
Nov 24, 2013 | Utilitech Pro 180-Degree 2-Head LED...
Jul 18, 2009 | Desa International 240 Deg. White Twin 150...
Flood lights take a very long time to come on
Insure you are using a standard flood light on motion sensor lights and not a florescent energy efficient flood light as they take longer to reach full brightness as the bulb filiment warms up. They are better suited for constant lighting rather than intermittent purposes such as sensor lights.
Good Luck
Nov 21, 2008 | Heath Zenith Electrical Supplies
Kitchen Appliances - Others Logo
2,892 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
