SOURCE: Pioneer PDP-503PU
Very possible,but yet,this might be the manufacturer defect power supply which they will fix it for you free;but before we jump to this conclusion,you need to test it first:
-Unplug the power cords.
-Unplug the media video cable from the box to the tv.
-Check all the pins on the video cable are in place as well as the connectors both behind the TV and the media box.
-Reconnect the media box and TV with the video cable(DVI+VGA in one) and have at least a video component hook up to it(ex. dvd player/VCR or comcast box) be sure this video player is turn on and running,at the same time,be sure it is under the right video input.
If you have tried the above steps but still doesn't work,call 1-800-pioneer Tuesday-Thursday at7amPST and address your issue to them.
Let me know if you have any additional questions!
solutiondoct
SOURCE: Pioneer PDP-5030HD power supply
click link -ebay shop selling power supply boards for 503hde/pe at 180 pounds you will have to contact him has he does not list them as pioneer are only ment to replace these boards or shops under contract with pioneer i changed mine and only takes min's when you have got the back cover off...
http://stores.ebay.co.uk/Plasma-Parts-UK
hope this helps mark doran
SOURCE: pioneer media receiver won t turn on
If the light on the media reciever doesn't come on then the power supply in that needs to be replaced by a service tech. If you disconnect the 2 cables from the media reciever and the panel and then try to turn on the panel it should light with red and green squares for a few seconds but will turn off as it needs the media reciever to be connected.
SOURCE: where can I sell a pioneer pdp 5070pu plasma tv for parts?
HI, the best way to do this is to disassemble the set and post all the individual internal parts like the power board and main PCB logic and v boards, on line on a e-bay type of sale forum. this way, you can make more money. if you post the entire plasma screen with the crack as is, you will not get many hits. is will be assumed that it is damage goods.
Breaking this set down and, posting the internal circuitry piece by piece will make you more money in this case. The power supply board will sale for at least 289.00. and the main logic(PCB) will sale for 300 to 350. i would go this route to maximizes your gain.
SOURCE: Pioneer PDP-RX06XE has no picture
check PDP 436XPE UNIT may be Y board short...or need factory restore to the original state....
