Question about Dryers
Help! Dryer runs but no heat. Need to remove
Help! Dryer runs but no heat. Need to remove elec. components to have tested to see which one is faulty but don't know where they are or what they look like. Whirlpool model # LEN3434AW ?? Can't seem to find any info on this model # iether.
  • melindadlth Jul 14, 2009
    yes, it's electric. Large capacity. I can see the heating element up inside from underneath the metal casing it's in. Already took back off. Thing is, if it's something else like thermostat or thermal cut-off, how/what to do next? Appliance parts store said bring in all so they can test. No return on electric parts. ??? Also, can't find my dryer model anywhere on the internet??? Trying to find manual. Thanks so much
  • bobby18rg May 11, 2010
    Electric dryer? Full size? Most likely the heating element . If elc the heating element is like the inside of a taster and they brake you must take the back off and look.
  • 5,911 Answers
The following link explains how to troubleshoot a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
The majority of dryer heat related problems are attributed to poorly installed, kinked or clogged dryer ventilation ducting. Pay particular attention to the paragraph that discusses the exhaust ventilation. Leaving a dryer in a clogged condition will result in repeated failures of any components you may replace, and it is a fire hazard.
Before assuming you have defective components in your heating circuits, you need to verify the voltage at the wall receptacle. If the dryer runs, but does not heat, the first thing you need to check is the wall receptacle for the proper input voltage. A reading across the two hot leads (left and right slots) should read 220-240 VAC. If this reading is incorrect, check your breaker panel. Some homes have the dryer circuit on two breakers, vice one single 220 breaker. If the voltage at the receptacle is good, unplug the dryer and remove the cover on the terminal block in the back of the dryer. Plug the dryer back in and take the same voltage check at terminal block across the RED and BLACK wires. You should see 220-240 VAC if good. If the voltage is bad at the terminal block, but good at the wall receptacle, you have a bad power cord. If the voltage is good at the terminal block, then the problem is internal to the dryer.
NOTE: The reason a dryer will still run if the input voltage is incorrect is because the dryer drive motor only uses 110-120 VAC, while the heating circuits require the full 220 service. So, if you are missing a portion of your input voltage, the dryer may exhibit the symptoms you have.
On your dryer all the heating circuitry is in the rear. Simply unplug the dryer and remove the back panel. The heating element is located inside the heater box on the lower right hand side. The Thermal Cut-Out (TCO) is located on the outside of the heater box at the end opposite the heating element terminals. The Hi-Limit thermostat is also located on the outside of the heater box, but is located adjacent to the heating element terminals. If you go to appliancepartspros.com and type in your model number, you can view explded view diagrams of your dryer along with the parts listing. The heating element is located under Section 3 as item number 17. The TCO/Hi-Limit thermostat repair kit is listed as item 6.
NOTE: It is strongly recommended that you replace BOTH the TCO and Hi-limit thermostat if one, or the other, is defective. That is why they are commonly sold as a set. Failure to do so may result in premature failure.
You can check these components yourself by using a multimeter. The TCO and Hi-Limit Thermostat will read 0 ohms if good. The Heating Element will read about 9 to 13 ohms. Make sure you take all measurements with the components unplugged for more accurate readings. The total cost of all your parts, combined is only about $50. Not bad if you do it yourself.
If you have any questions about this repair, please let me know. I hope you find this information helpful.
Posted on Jul 14, 2009
    President:
  • 1,723 Answers
Watch the video for help:
My PYE3200AYW runs but will not heat. Changing
Check for a blown thermal fuse or a faulty heating element. Both components should be located inside the rear of the dryer2.gif. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity will indicate a faulty component. Really sorry for your trouble and I hope this helped. Best wishes.
Oct 08, 2009 | Maytag PYE2300AY Electric Dryer
The dryer runs but no heat
Check for a blown thermal fuse or a faulty heating element. Both components should be located inside the rear of the dryer. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity will indicate a faulty component. Really sorry for your trouble and I hope this helped. Best wishes.
Oct 03, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
Running with no heat
Sep 30, 2009 | Danby DCD5505W Electric Dryer
Kenmore Dryer model 110.62932100
First, make sure that there is no ventilation issue and that the vent is clean and clear. If the dryer isn't heating, check for a blown thermal fuse or a faulty heating element. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. Both components are located in the rear of the dryer. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Remember to disconnect the dryer from the power source before attempting any repair.Sorry for your trouble and I hope this helped. Best wishes.
Sep 29, 2009 | Kenmore 659 Electric Dryer
For Dryer Model LER7646EQ1, dryer runs but no heat, It could be the heating element, the thermal fuse or other. Also the dryer has been running hot.I do not know how to remove the front panel
This sounds like a faulty thermal fuse or heating element. The fact that you said the dryer has been running hot could indicate that the heating element was making contact with the heater box or the high limit thermostat is faulty. Both the thermal fuse and heating element can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity means a faulty component. When necessary to replace a thermal fuse it is best to change the high limit thermostat as well. They will sometimes come as a set from a parts supplier. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 23, 2009 | Whirlpool LER7646E Dryer
Have run the same load four times and clothes are still damp. Problem just started.
If the dryer isn't heating, check for a blown thermal fuse or a faulty heating element. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. Both components are located in the rear of the dryer. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Hope this helped and best wishes.
Sep 06, 2009 | Estate EED4300SQ Dryer
Dryer stop heating because of flood. motor still runs but theres no heat
It doesn't say, but if it is an electric dryer, check for a blown thermal fuse and faulty heating element. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. The thermal fuse is about an inch long and is inside the rear of the dryer, usually attached to or near the exhaust duct. Sorry for your trouble and I hope this helped. Best wishes.
Sep 01, 2009 | Dryers
Dryer runs but doesn't heat up.
Check for a blown thermal fuse or faulty heating element. Both components can be tested using a multimeter or ohmmeter. Test for continuity. A lack of continuity indicates a faulty component. The thermal fuse is about one inch long and is located just inside the rear of the dryer and is usually attached to the exhaust duct. Sure hope this helped and best wishes.
Aug 08, 2009 | Roper Dryers
No heat when dryer running - Maytag mdg6000
Check for a blown thermal fuse or a faulty heating element. These components can be tested for continuity using a multimeter. A lack of continuity indicates a bad component. The thermal fuse is about one inch long and is located in the rear of the dryer and is usually attached to the exhaust duct. Hope this helped and best wishes.
Aug 03, 2009 | Maytag MDG6000 Dryer
Runs no heat
heat coil is probably your culperate
Jul 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
271 people viewed this question
Top Dryers Experts
