Question about Epson Stylus Pro 4000-PS InkJet Printer
The magenta ink head is clogged and no matter what I do I can't get it unclogged. Since I can't get it to work I haven't used the printer in weeks and now am worried all the heads will clog. What should I do if I am not using the printer for an extended period of time? Remove all cartridges? And, then what? Thanks very much, Tess
    Scholar:
  • 144 Answers
Hi
try using a damp lint free cloth and try cleaing the cartridge ****.
also if you go in to the printers and faxes and rt click the printer icon and goto properties you will find clean ink cartridge under maintenance.
try cleaning the ink cartridge using that
and the cartridge should work absolutely fine.
Posted on Jul 14, 2009
My canon pixma ip4000 has stopped printing. It is going through the motions but the paper is coming out blank with nothing on it.
Hi
If you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your Canon PIXMA iP4000 InkJet Photo Printer has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Or possibly a faulty cartridge.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use the Magic Inkjet Flush kit to soak the print head and you should be printing again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros (Ebay)
Nov 23, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
No I see no solution noted here. again Photosmart D7360 error message 0xc18a0001 ink system failure.
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
So if yours appears to be a clog? all you should need to do is to usethe Magic Inkjet Flush kit to soak the print head and you should beprinting again like new.
Also this may help...
HP 145 Sequence HP D145 all-in-one printer
http://magicinkjetflush.com/images/PDF/HP_135_Sequence.pdf
or smaller file
http://magicinkjetflush.com/images/HP_135_Sequence.jpg
Good Luck!
Tinteiros (Ebay)
Oct 31, 2009 | HP Photosmart D7360 All-In-One InkJet...
I put a new color cart in and now my pictures have a green hue to them
Hi
Sounds like too much cyan.
Remove ink and place onto a paper towel.
If it appears too much cyan *blue then let it stand for 2 mins. You can do the same if mixed.
Once normal colours appear try again.
Good Luck!
Tinteiros (Ebay)
Oct 31, 2009 | Lexmark P4350 All-In-One InkJet Printer
Prints like it is running out of ink, but it is a new cartridge. Some sentences are printing, others are blank, or partially printing.Followed instructions to align and clean nozzles. Doesn't help.
HTML clipboardIf you have lots of flashing error lights or electrical problems then it is likely to be electrical.
Good Luck!
Tinteiros (Ebay)
Oct 30, 2009 | Dell 946 All-In-One InkJet Printer
Can not get printer to print keeps saying that it is idle in the que
Hi Pull the power cable. And leave out for 1 minute it should reset to default factory settings.
However, if like most... and yourprinter has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Magic is ideal for unclogging the tiny jets on any Canon,Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to usethe MagicInkjet Flush kit to soak the print head and you should beprinting again like new.
or smaller file
Good Luck!
Tinteiros (Ebay)
Oct 30, 2009 | HP Photosmart D7460 Printer
HP Photosmart C6180 Magenta Inks Not Printing
However, if like most... and yourprinter has just been left unused for some time? You probably have an ink clog on magenta.
Magic is ideal for unclogging the tiny jets on any Canon,Epson HP and removing those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use the MagicInkjet Flush kit to soak the print head and you should be printing again like new.
or smaller file
Good Luck!
John P Bradley
Tinteiros (Ebay)
Oct 30, 2009 | HP Photosmart C6180 All-In-One InkJet...
After replacing cartridge in dell 810 the colours printing wrong
Hi
If you haven´t used your inkjet printer for a while it may just be dry ink clogging some of the nozzles in the print head.
To check if yours is clogged...
Remove the ink cartridges
Holding the cartridge upright and press down gently onto a paper towel.
The colour cartridge
you should see YELLOW, MAGENTA (red) and CYAN (blue)
But if any colours are missing? The inks have probably just clogged up? and you will need to buy a new one or if you know you still have ink then you can easily unclog it with a
Magic Inkjet Flush Kit (Which you can find on Ebay)
MIXED COLOURS
If you have others colours coming out then the colours have mixed...
Sometimes caused when people put tape onto the inks to keep them moist but instead the colours mix through capilary action.
If so... leave print head sitting on a paper towel for a few mins until the correct colours appear.
Read more about ink clogs here:
To prevent an ink clog it is best if you print something regularly about every 10 days to keep the tiny print head nozzles / jets open. Otherwise the ink in the print head will thicken. Then it´s like trying to pass a camel through the eye of a needle.
So to preven inkjet ink from clogging print something every 10 days if you dont have anything to print, use something like these test prints
PRINT TEST SHEETS FOR USE WITHMagic Inkjet Flush
http://magicinkjetflush.com/Ebay/Print_Test_Black.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Color.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Cyan.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Yellow.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Magenta.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Grey_Tones.jpg
Good Luck!
Hope this helps you!
Tinteiros (Ebay)
Oct 28, 2009 | Dell 810 All-In-One InkJet Printer
Canon pixma 3000 won't print red
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog on the magenta *red.
But provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
You are covered by a 30 day money back guarantee if not.
Good Luck!
Tinteiros (Ebay)
Oct 28, 2009 | Epson Stylus C86 InkJet Printer
Canon MP510 skips and makes 2 small blank lines going DOWN the pages, in only cyan and magenta. The two lines show up on the Nozzle Check Pattern but only on cyan and magenta.
Magicis ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
Good Luck!
Tinteiros (Ebay)
Sep 11, 2009 | Office Equipment & Supplies
Epson C82 & C84 Printers will not laydown any ink!
Sorry but It uses Durabrite ink which tends to turn into hard gel if not printed at least once a week. Its less painful and expensive to just throw the printer out and buy a new one. I recommend the canon PIXMA ip3500. It lets you remove the printhead for cleaning unlike the Epson. If you want to try your luck at unclogging the printer heres a link to a unclogging kit but be warned that results are not guaranteed!
http://www.fixyourownprinter.com/kits/Epson/K89
The C82 in addition to clogging also has a problem where the waste ink hose which is supposed to remove excess ink (so the printer dosent get clogged) gets disconnected and so the printer clogs even more. The C84 had this glitch fixed but alot of good that did!
Thanks for reading!
Apr 10, 2008 | Epson Stylus C84 InkJet Printer
Epson Stylus Pro 4000-PS InkJet Printer Logo
357 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
