Question about Intel Computers & Internet
Where will i find a FSB HT2000/1600 manual - Intel Computers & Internet
    Scholar:
  • 111 Answers
I believe you must do some reading to understand this.
http://www.intel.com/products/ht/hyperthreading_more.htm
http://www.directron.com/fsbguide.html
http://en.wikipedia.org/wiki/Front_side_bus
I hope this sheds some light on the subject.
Posted on Jul 15, 2009
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
My athalon xp2000 processor died. What can I replace it with that is compatible with k7s5a motherboard?
There are several versions of the K78S5A. The following answer applies only to v.3.x.
CPU: AMD Duron 200Mhz FSB CPU - 950 AMD Duron 266Mhz FSB CPU - 1800
AMD Morgan 200Mhz FSB CPU - 1.3G
AMD Athlon 200Mhz FSB CPU - 1.4G AMD Athlon 266Mhz FSB CPU - 1.4G
AMD Palomino 266Mhz FSB CPU - 1.2G
AMD Athlon XP (0.18u) 266Mhz FSB CPU - 2100+ AMD Athlon XP (0.13u) 266Mhz FSB CPU - 2600+
I hope that helps! Good luck.
GaugeMan
Mar 06, 2011 | EliteGroup K7S5A Pro Motherboard
BOA NOITE! TENHO UMA PLACA FSB 2000 MT\S PRECISO DO MANUAL PARA LIGAR OS CABOS. OBRIGADO.
I guess you need the manual for your motherboard ABIT UL8. You can download from here.
Dec 06, 2010 | Abit UL8 ULi M1689 Chipset 2000MT/s FSB...
Trying to find the Jumper that controls FSB on a dell dimension 8200. Either that or some form of overclocking software that will allow me to get the full 2.8 out of my P4
modern Boards Auto-Detect FSB speeds, usually determined By CPU fsb And Memory/Ram speeds. It may be Wise to see if theres A user manual/guide for this board. or a possible bios update to support the CPU. also check the boards fsb speed ratings charts. overclocking is not recommended, as this can damage cpu/ram and motherboard.
Mike @ Compurepair.
Oct 29, 2009 | Dell Dimension 8200 PC Desktop
Ax4per with 1.8GHz does not recognize new 2.8GHz processor. Socket 478. BIOS is current. Is it not plug and play?
Does it POST and can you get into the BIOS? You need to set the FSB to 133MHz and the Ratio to 21x.
(I am assuming you did install the CPU correctly and installed the fan.)
If you can't get into the BIOS, you may need to reset it using JP14 on the motherboard.
Turn OFF power. Remove the AC power cord. Hold the power button in for 5 to 10 seconds. (This is done to discharge any capacitors.) JP14 normally is on Pins 1 and 2. Place the jumper on Pins 2 and 3 for approx. 10 seconds. Then place it back on pins 1 and 2. Connect the power cord and turn it on. This will set all the BIOS settiings to default and you should be able to set the FSB and Ratio.
Do you have a manual for the MB? you can get it from:
ftp://ftp.aopen.com/pub/manual/mb/ax4per/ax4per-ol-e.pdf
Thanks for using Fixya.
Wayne
Sep 10, 2009 | AOpen AX4PER 845PE P4-533MHz...
CPU compatability
It is not compatible. If your fsb is 533mhz then any replacement cpu would need to be a 533mhz fsb chip. This is unless your motherboard supports different fsb's. You will need to check your manual or the manufacturers website to see what cpu's your system supports. Hope this helps.
Jun 01, 2009 | Acer Aspire 5315 Notebook
ASUS P4S333-M What is the maximum CPU this bouard will run
P4S533-MX
The following table shows the support for CPU / Motherboard
CPU
Since PCB
Since BIOS
Note
Celeron 1.7 GHz (400 FSB, L2 cache:128KB) ALL
ALL
Celeron 1.8 GHz (400 FSB, L2 cache:128KB) ALL
ALL
Celeron 2.0 GHz (400 FSB, L2 cache:128KB) ALL
ALL
Celeron 2.1 GHz (400 FSB, L2 cache:128KB) ALL
ALL
Celeron 2.2 GHz (400 FSB, L2 cache:128KB) ALL
ALL
Celeron 2.3 GHz (400 FSB, L2 cache:128KB) ALL
1005
Celeron 2.4 GHz (400 FSB, L2 cache:128KB) ALL
1005
Celeron 2.5 GHz (400 FSB, L2 cache:128KB) ALL
1006
Celeron 2.6 GHz (400 FSB, L2 cache:128KB) ALL
1006
Celeron 2.7 GHz (400 FSB, L2 cache:128KB) ALL
1006
Celeron 2.8 GHz (400 FSB, L2 cache:128KB) ALL
1006
P4-1.4 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-1.5 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-1.6 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-1.6A GHz (Socket478, 400 FSB, L2 cache:512KB) ALL
ALL
P4-1.7 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-1.8 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-1.8A GHz (Socket478, 400 FSB, L2 cache:512KB) ALL
ALL
P4-1.9 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-2 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-2.20 GHz (400 FSB, L2 cache:512KB) ALL
ALL
P4-2.26 GHz (533 FSB, L2 cache:512KB) ALL
ALL
P4-2.40 GHz (400 FSB, L2 cache:512KB) ALL
ALL
P4-2.40B GHz (533 FSB, L2 cache:512KB) ALL
ALL
P4-2.50 GHz (400 FSB, L2 cache:512KB) ALL
ALL
P4-2.53 GHz (533 FSB, L2 cache:512KB) ALL
ALL
P4-2.60 GHz (400 FSB, L2 cache:512KB) ALL
ALL
P4-2.66 GHz (533 FSB, L2 cache:512KB) ALL
ALL
P4-2.80 GHz (533 FSB, L2 cache:512KB) ALL
ALL
P4-2A GHz (Socket478, 400 FSB, L2 cache:512KB) ALL
ALL
P4-3.06 GHz (533 FSB, L2 cache:512KB, HT, C1/D1) ALL
ALL
Since PCB 2.0 or later support HT Function
Jun 22, 2008 | Computers & Internet
Upgrade
Thank you for the information. Please find the CPUs supported by the Motherboard of your computer below.
Duron: 1.6 - 1.8 GHz at FSB 266 MHz
Athlon XP:
Palomi** Core: 1500+ - 2100+ at FSB 266 MHz
Thoroughbred Core: 1700+ - 2700+ at FSB 266/333 MHz
Barton Core: 2500+ - 3200+ at FSB 333 MHz
2500+ - 3200+ at FSB 400 MHz
Sempron: 3000 + and up
I see that the present processor is requires ** upgrade as it is one of the best match availble for this motherboard. However, you can upgrade the Memory to 2 GB using two 1GB
DDR 266/333/400 modules to improve the system perform performance. Also, you can consider for a video card upgrade. Your computer supports both AGP and PCI video cards.
Also, you can download the maunal for the motherboard of your computer from the link below for your referance.
http://www.elhvb.com/mboards/oem/emachines/manuals/K7MNF-64_manual.zip
Regards
Mar 07, 2008 | Computers & Internet
Mobo FSB speed
Clear CMOS jumper Jumpers to enable system wake up on keyboard or USB devices PS/2 keyboard power jumper Fan power jumper Jumpers to enable/disable SMBus 2.0 support This is the jumpers which is avalable for the motherboard.
If there is no jumper for your oparation It will detected the changes Automatically.
Feb 10, 2008 | ASUS P5GD1 Motherboard
Computers & Internet Logo
520 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
