Where do i plug in my speakers to the back of computer
Speakers have a purple plug end and there is no purple plug hole
You put it in the greenhole, if you look closely at the greenhole there should be a really small headset image. The red hole is for the microphone, if you look at that it should have a small image of a microphone
Posted on May 31, 2010
How do i hookup the what i think is the power cord to the computer its a round plug in
If it's a power cord, it doesn't plug into the computer; one end goes in the wall, the other into the speakers.
For most speaker pairs, there are 3 wires:
1) The wire that connects the speakers to each other. That's often fused into the back of the left speaker, and gets plugged into the right speaker (it's usually pretty well marked where to plug it in).
2) The wire that connects the right speaker to the computer. Usually it's pretty well marked where to plug this into the speaker. On the computer, that wire will fit into 2 ports. Usually those ports are marked with microphone and headphone icons. You want the headphone jack. If they aren't marked, try them both or check your manual.
3) The power cord. One end of that will plug into an electric outlet on the wall (or into an extension cord or power strip). The other end will plug into the right speaker; it should only fit into one hole (which will probably be marked with "12V" or "0.5A" or something like that).
It would help if you told us what kind of speakers you have, and what kind of wires you're seeing.
Mar 02, 2015 | Audio Players & Recorders
Tip
How to wire multiple speakers to one channel.
This mainly concerns surround sound systems, with a subwoofer. It is possible to wire multiple speakers to one channel, most useful for subwoofers. Even though bass is nondirectional, the user can still sort of place it. I create "surround bass" with one subwoofer channel. Enough intro.
I purchased two old Sansui LM-110 multi-driver(woofer and tweeter with a passive crossover) and placed them around the back wall till i liked the positioning. I then replaced my ht-z320 subwoofer with a Samsung PS-WX50(from the HT-X50 system). The X50 went in front, under the TV. The wiring to he speakers must be exactly as follows, lest the amplifier in the main unit repeatedly shut the unit down to protect(PROT then shutdown) from damage.
This is easier to do if you know how to solder(it also grants better sound), but can be achieved with a twist on wire connector and wire strippers.
The purple plug positive(denoted as a + inside a circle) keeps its wire, going to front woofer(Samsung PS-WX50) RED. Cut some speaker wire to the back woofer last on the route the wire will take to the rear woofers. Split it, then cut one of the two wires on the speaker wire at the other woofer. strip both ends. Do this to two equal lengths of speaker wire. Split and strip the joined ends of the first wire and connec both ends to the black port on the front woofer, the othe ends to the back woofer RED ports. Take the other wire, join the unsplit ends to the negative wire(helps to cut that short) in the purple plug, using your wire nut. Strip and connect the other ends to the black ports on the back woofers. This basically is a series setup. The back woofers are one one parallel circuit, but are powered as one speaker. therefore, the front speaker and both back speakers(acting as one) are a series loop. To simplify, unit + to front red. Front black to both back red. Both back black to unit -.
on Jun 13, 2010 | Audio Players & Recorders
Trying to connect the SHTIB1044 P to my computer how can I connect the sylvania speaker system to my computer?
On the back of your speaker power unit you should see a hole at the top for a audio input it should be a 3.5mm jack hole on the back of you computer you should have speaker output or on a laptop you should have a head phone jack it should be 3.5mm as well if you don't have a double ended 3.5mm jack thats what you need hook one end into the computer end and one into the audio in on the speaker power box end make sure you get one long enough to reach where ever you are placing the comp. or laptop. plug everything else up as it should and it should work yu will need the power up on the laptop to get full use of the speakers or set it at a good range for controlling it with the windows volume control.
Nov 01, 2011 | Sylvania G-Netbook
Everything is unplugged, I just need a wiring schematic to plug everything back in
Does the motherboard have a "purple" socket?
Does your keyboard have a "purple" end?
If so, join the male to the female,
rotating the male until the stiff pins line-up with the holes.
Does the motherboard have a "green" socket?
Does your mouse have a "green" end?
If so, join the male to the female.
The end on the monitor's video-cable has 3 rows of pins;
there's only one place on the computer with 3 rows of holes.
Notice that the sides of the male are tapered,
so that it only fits ONE way into the female.
Similarly, the female end on the power-cord is tapered,
so that it only fits ONE way into the back of the computer.
Note where it connects -- there may be a "rocker" switch,
with a '1' and a '0' on the ends of the rocker.
Press the '0' end down before you reconnect everything.
Press the '1' end down after everything has been reconnected.
Do your PC speakers have a green tip?
If so, then connect the male from the speakers to the green female socket.
Sep 14, 2009 | 3Com Computers & Internet
NO SOUND
They should be plugged in and turned on when you power up your system.They should be plugged into the green jack (line out). You then may have to check settings in control panel for your sound card's properties to see if digital only is checked. Try it both ways. Hope this helps.
May 22, 2009 | Boston Acoustics BA735 Computer Speakers
I Do Not Know How To Connect Boston Micromedia To My Computer
The Boston Micromedia speaker set comes with two speakers (right and left),a subwoofer, and a complete set of cables to connect everything up.
1.) Position the speakers. The two small speakers typically are spaced equal distance apart on a desk/table top to the benefit of the listener. The sub-woofer typically rests under the surface, on the floor for example.
.) Connect the cable sets to the back of the two small speakers along with the speaker feet.
Note: the small speaker with the volume control knob will have three cables coming from it. This will be the "right" speaker. The other speaker will have a single cable and will be the "left" speaker.
2.) The cable ends will be color coded to match the jackson the sub-woofer. Match up the color coded cables to the respective colors on the subwoofer as follows:
(a) White cable end (left speaker) to white jack on sub-woofer.
(b) Red cable end (right speaker) to red jack
(c) Purple cable end (input) to the purple jack
(d) Green cable end (computer out) to the computer's microphone output jack.
Note: if any of the cables are too short to reach their jacks for whatever reason, an extender cable with a female and male end can be purchased relatively inexpensively to make up the difference in distance.
3.) Power up the system (plug in power cables to the sub-woofer and wall), play some music, and adjust the sub-woofer sound (control knob) to suit listening pleasure.
A nice little set of speakers, I had mine for some years now and continue to enjoy them. Good luck!
May 17, 2009 | Boston Acoustics MicroMedia Computer...
No sound
Try plugging in earphones to see if the problem is the speakers or the output from your computer. Also, your computer output may be low power output for powered speakers and your speakers are not compatable. You may also be plugged in to the wrong output on your computer.
JG in AZ
Apr 11, 2009 | Boston Acoustics BA7500 Computer Speakers
I am a computer dummy...How to I connect speakers for sound like music in my computer?
The end of your speakers should have a green plug, on the back of your computer there is a green port. Insert the green plug into the green port. If you have a power cord for your speakers you need to plug that into the wall.
Please rate my answer, and good luck.
Jan 20, 2009 | Computers & Internet
Connecting jbl speakers to imac osx
Your speakers should have a wire with a stereo plug at the end. Sometimes they are color coded green, sometimes not. Try to find a plug that looks like the one here:
http://www.ethnicdance.net/minidisc/Analog_Mini_Plug.jpg
Now look at the back of your iMac. Around all the other wires and plugs, you should see 2 holes that this speaker plug will fit into. One of the holes has a headphone symbol and one has an output or speaker symbol. Plug it into that one and you should be good to go. You probably also need to plug the speakers into a normal outlet for power. And make sure you turn the volume up because new speakers usually come with it turned all the way down to avoid sudden loud noise when it's plugged in.
Jan 06, 2009 | Harman Multimedia T9078 2.1 Speakers
Connection my speakers
You should be able to plug them into the the green jack on the back of the computer. Next go to the volume control panel, usually under start, programs, accessories, entertainment, volume control. now make sure that the master volume is all of the way up, and that the Wave, SW Synth, and CD Player are not muted. THis should work, if your computer also has an output on the front, make sure to switch the output selection to the rear, by using the software, that should be preinstalled.
Feb 23, 2008 | Acer Aspire™ T180 PC Desktop
783 people viewed this question
 Grubhead
Grubhead
