Question about Black & Decker Toast-It-All Plus T4550 4-Slice Toaster
I need to clean it out thoroughly. pills and
I need to clean it out thoroughly. pills and stuff have fallen in. how do i get the cover off
  • 408 Answers
There are screws on the bottom to reove the tray and cover.
Posted on Jul 14, 2009
TCL272 WHAT KIND OF PILL?
Is is an expectorant for bronchial (lungs) problems. Brings up the green stuff :>)
TCL 272 Pill images White Round
Mar 31, 2018 | Health & Beauty
How safe is it to use pills for reducing weight?
Safety is really a matter of concern while opting to choose the weight reduction pills. We need to thoroughly make sure that the product is very sure and safe to use!. Because after consuming some fake products there is no point in worrying about your health. So be sure to use only recognized products that are well established. Even I have tried using pills to lose weight and one product of my choice is the Best Weight Loss Pills 2018, they have provided me quick results. they are very affordable and sell their products at a very reasonable price too!.So you can be sure to sue these products!.
Dec 04, 2017 | Health & Beauty
I need to know what these pills I have that have fallen loose are. They are white and round. They have a slash across one side and TV over 53 on the other side.
Take them to your pharmacist and ask them, they are the only people you should believe, otherwise throw away. If you do not recognize them it may not even be your pills.
Oct 07, 2017 | The Health & Beauty
The throttle linkage is screwed up on my Stihl MS 170 and I'm not sure what's going on with it.
It looks like you need to clean out the beautiful Stihl saw thoroughly! The switch is working when the cover is off, right? So, one can conclude that the cover is the problem, or at least, in part. Use some compressed air onthe WHOLE saw to get the crud out! use a brush to knock off the sticky stuff. Clean the machine after each use and that saw will last a lifetime!
Jan 01, 2013 | Garden
I have a kirby lester KL15 pill counter that gives an E4 error code, any help would be greatly apprecicated.
Tablet dust or residue on detector windows. Clean glass detector windows thoroughly.
Sep 12, 2012 | Office Equipment & Supplies
Suzuki HG425E All the contacts for the keys are in bad condition and need to be replaced. Where can I buy such assemblies?
The contacts probably just need cleaning. Often they are conductive rubber "pills" in silicon domes that the key presses down against a circuit board under the keys. Clean the pills AND the circuit traces they press down on with ONLY 99% isoprophyl alcohol and Qtips. Be gentle in cleaning. Most of the work is accessing the contacts. Note these contacts do NOT for a low resistance contact as the electronics doesn't need a good contact. There are two per key to implement sensing key velocity. Sometimes the contacts are coencentric with a pill inside a ring of conductive rubber. The conductive rubber is always black.
Apr 21, 2011 | Suzuki S350 Mini Grande Digital Piano...
When played, two of the keys sound much softer than usual. The pitch of the note is correct, but the velocity does not match the neighbouring notes. Q1. Is there a mechanical velocity sensor, that...
The velocity is usually sensed by having two contacts for each key. The contacs are usually a conductive rubber pill or sometimes a ring around another pill that press against traces on a circuit board under the keys. You need to clean both the pills and the traces with ONLY 99% isoprophyl alcohol and Q tips. These are usually in "domes" of non-conductive silicone rubber under the keys.
Be careful of the cables when you open the covers of the unit.
Nov 25, 2010 | Roland Juno-D
I am repairing a LaCimbali M2 BarSystem that has a broken gear (Nylon) that transfers Torque from the Motor to the drive shaft on the grinder. Can this gear be purchased separately?
Sorry no, the gear drive assembly comes complete with the motor drive. Broken gear is usually caused by something getting into the dose chamber. I've found may an object stuck in the chamber, Don't leave stuff on top of the machine. Don't use hard cleaning pills (check old coffee 'pucks' for unmelted pills) Gross overfilling of coffee will also break gear. Check for oversized coffee pucks (double dosed?)
ukeboy57
Oct 11, 2010 | Espresso RMI La Cimbali Espresso Machine
My psr-230 keyboard does not work well, some keys
The key contacts proabably need to be cleaned.
One has to disassemble the unit being very careful of cables. Do not force anything.
The contacts are usually black conductive rubber "pills" under silicone rubber domes. These are often in strips covering several key contacts.
Clean both the pills and the circuit traces on the board they contact with 99% isorophyl alcohol and Q-Tips.
Jan 23, 2010 | Yamaha Music
It's a Roland HP-7e digital piano about three years old.
You may need to clean the contacts which are usually conductive rubber. I explained stuff for another Roland problem with two keys that were intermittent. I have an EP-7 that I had to do the cleaning of the key contacts. Use 91 or 99 % Isoprophyl alcohol to clean BOTH the conductive "pill" (Black under silicone rubber domes) AND the traces on the board where they press. Clean gently as the traces have a hard black coating.
Jul 26, 2009 | Roland Music
Black & Decker Toast-It-All Plus  T4550 4-Slice Toaster Logo
170 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Irene Tulloch
Gerry Harvey
Gerry Harvey
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
