Question about Toshiba E-STUDIO 450 Copier
Add a new email address
I need to add a new email address so I can scan
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 103 Answers
If you are connected thru the network the best way is to start Top access then click registration tab,then address book. on that page you will find add address.
or on the machine press "user functions",then tab address,then press address book,find free slot, press entry. there u will find space everything. after U enter just confirm that and that it.
Posted on Oct 29, 2009
How do I add a fixed email to scan so I don't have to input address every time?
You can create user (email) in address book from copier control panel as well. Then when you press scan, the email contact address will be there to select.
Jun 24, 2014 | Toshiba estudio 255 Copier
Hi we have just installed a gestetner asm645 (i think thats its name), and want to delete the old companies accounts as when we try to scan something it says it needs a "senders" account to scan...
can delete user accounts under system settings. Press the button marked 123(where you get your meter reading). under system settings go to administrator tools and address book managments. can delete user accounts and create new 1's. Or you can trun the user authentcation off. Then no code is needed.
Sender - under system settings go to file transfer. input your smtp and managers account email. When programing user in address book look for add as sender and input the email address. When emailing you can select sender and destination. If the user is not set up as a sender the list will be empty and you would not be able to select a sender. set up a user (email) that any one can use.
Jan 21, 2011 | Gestetner Copier
How does a user store an email address for later use when scanning?
you need to go into the user tools and administrator tools> then to address book > then add new enter the name and the email address of the person you require. you will need the administrators email address to use as default password to clear through server. when you have done this if you go to the scanner button you should see the user there.
Jul 07, 2010 | Ricoh Office Equipment & Supplies
How do you add and delete users' emails for scanning
U can store all the users emails on address books. Then when u want to perform scan to email, just press the email button on the particular to add, re-press again to remove.
Jan 08, 2010 | Toshiba E-STUDIO 650 Copier
Entering email destinations in scan mode
Thru web image monitor, type the ip address into a web browser (upper portion) so if ip is 178.005.045.100 type in 178.5.45.100, sometimes the 0's wont allow you in. Log in as an administrator. name is admin no password. and add your name and display name and in the lower portion the e-mail address. -Carl
Jul 09, 2009 | Ricoh Office Equipment & Supplies
Set up email/scan
moz-screenshot.pnghere's how to add contact to the address book:
  1. press FUNCTION key
  2. select FAX/EMAIL SETTINGS icon
  3. select ADDRESS BOOK
  4. select ADD EMAIL ADDRESS
  5. input your email address
  6. input your name
  7. select ok
  8. input a key name
  9. you can choose if you want to add it to favorites or not
  10. press stop key to return to idle state
that's it :)
Jun 12, 2009 | Panasonic DP-8045 Grayscale Copier
I need to change a name and set up scan to email
As far as the name goes, I assume that it must be a watermark / overlay that is programmed into your printer driver. Go to the printer "properties" and go into "printing preferences" and select "custom settings", and check the watermark/ overlay settings.
There are a couple of different drivers , so the location of this could vary slightly.
As for programming Email?
If you have some addresses programmed and working already?
The easiest way to add more is to open a web browser and type your printer's ip address in the address bar, select "administrator Mode".
The default user name is "admin". The default password is either "password", or just leave blank (can't remember which)
select "address book", then you will see the names of the destination you have programmed. If you highlight one of them and select "change" you will be able to view the settings that need to be made. Then exit out of that page, and select "add" and input the information for the new destination.
If you have not setr up scan to email, you will need to make many other settings in the web browser that I cannot go through, but it involves all of your TCP/IP settings, email settings such as user name, password, SMTP, POP, etc...etc.
Hope this helps.
Feb 24, 2009 | Ricoh Office Equipment & Supplies
Scanner - adding new email address onto the system
Go to your web browser and type the IP address of the MFP.
There you will see a tab along the top where, when clicked will let you enter address into the address book.
The MFP MUST have the email set up first, just like a computer as far as domain servers and it also needs a valid email address to log on and send off the messages.
This can be done on the panel of the MFP or by logging out and then back in as the admin through the web browser again.
Oct 22, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Cannot scan to email Konica Minolta 250 Bizhub
To scan to email, Administrator email address must be set in the machine (any bogus email address will work too).
Also, email server address must be input as IP address if DNS or WINS is not running in LAN.
Mar 03, 2008 | Konica Minolta bizhub C250 All-In-One...
BIZhub C250
try the web based configuration
Apr 18, 2007 | Konica Minolta bizhub C250 All-In-One...
1,013 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
