Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
Placing the belt on LGT2654
MODEL LGT2654 THE BELT CAME OFF NEED INSTRUCTIONS ON PUTTING IT BACK ON
Does anyone have a layout on how the belt goes on the 2554
Posted on Jul 28, 2009
Husqvarn lgt2654 wont pull
Make sure the drive belt is routed right. Go to partstree.com click on
husqvarna and put in your model number and click on the drive scematic and it will show the routing of the belt.
Jun 23, 2012 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Model 2254 deck belt jumped loose, need diagram as to how it winds "top view"
hi there senator359
pauly46 here
please find web site for a manual that has belt roueting in it
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2008/HOUS2008_O0802053.pdf
it is lgt2654
go to web site down load and print
here is husqvarna gth 2254 web site for diagram
http://www.partstree.com/parts/?lc=husqvarna&mn=GTH+2254+XP+(96023000201)+(2005-06)&dn=86020023
check them both out
let me know if helps
dont forget the thumbs rating
cheers pauly46
Jul 08, 2011 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Need belt diagram on husqvarna lgt2654
Here is your manual. Please see Figure 5 on Page 7 for the deck belt routing. Other useful diagrams and pictures are in this manual as well.
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2006/HOUS2006_O0602065.pdf
May 02, 2011 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Need instruction for replacing a drive belt on a electric dryer Model No. DE482 Serial # 07
Best to move the dryer to a big room (hopefully cardboard if carpet is not available) as you will need to move around and move IT around some. Once you've got a nice clearance to work in, place the dryer onto its FACE-to clarify, the side that has the door that you open to access clothing articles should be on the ground. You will need to remove the back panel. This is the only way that you can replace the belt as there is a belt tensioner you will need to access also. The belt is long but not very wide or thick. There will only be one way you can fit the belt in place, have it be nice and tight, without having any slack. You might need a friend to hold the belt in place around the large DRUM (the area clothes are placed for drying) while you are routing the belt into place. There are only 3 places that the belt needs to contact: The DRUM, the motor shaft (this is what causes the belt to turn the drum), and the belt tensioner. The drum (with a friend holding the belt in place) and the motor shaft should be a snap, it might take a couple of tries to figure out how to correctly route the belt through the tensioner. When you have routed the belt correctly, the belt will be snug, the tensioner should flex (a little), and should be in the same spot the old one was. There is NO WAY you can install it backwards. Before putting the back panel on, turn the drum by hand a little to make sure you haven't missed or forgotten anything. Not a big job, not time consuming, just be careful you don't take any shortcuts and it should turn out great!
If you need more help, I found parts breakdown prints here:
http://www.appliance-parts-warehouse.com/maytag-parts/model_view_cats.cfm?model=DE482
Hope this helps!
Nov 08, 2009 | Dryers
Remove blade clutch from a Husquavrna 4817iz zero turn more.
Remove the footrest. Apply pressure to the belt tensioner to loosen the belt, slip the belt off the pulley opposite the tensioner. Remove the belt from around the electric clutch. Unplug the electric clutch (2 pin connector With a socket wrench, remove the bolt in the end of the crankshaft which holds the electric clutch in place (you may need a piston stop or other device to keep the engine from turning in order to do this), then remove the clutch. Installation is the reverse of removal
Oct 25, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Cant get a deck cutting belt for model YTH 2448T960430008 48 INCH CUT TRACTOR MOWER
which belt do you need the primary or secondary i have part # for ya i can also order them 180808 & primary part # is 174368 let me know if i can further help thanks wade
Jul 07, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Need drive belt diagram for LGT2654 Huskee
Here is a link to the manual on pages 7, 8, and 40,
Please take time to rate this a fixya
May 10, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Changing of belt
Step 1: Lower handle to floor to change belt
Step 2: Remove the two screws from the top hood on the foot
Step 3: Lift hood to remove
Step 4: Lift right end of brushroll (the belt end)
Step 5: Remove and discard belt.
Step 6: Place new belt around motor shaft.
Step 7: Place new belt around brushroll pulley.
Step 8: Align left end cap with base. Push end cap securely into
place. Make sure the square on the brushroll cap is in
place
Step 9: Pull right side of brushroll to stretch belt. Secure right
end cap into base.
IMPORTANT
Step 10: Rotate brushroll by hand several full rotations to properly
position belt.
Step 11: Place hood back on cleaner. Replace and tighten
two screws.
Step 12: Return vacuum to upright position.
You can also download your user manual here which has instructions on how with diagrams
Dec 24, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
459 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
