Question about Cell Phones
Kuxing K1000 Phone | White Screen of Death
So I just got it right, I turned it on worked fine. It came up with asking me for a pin. I wasent sure so I turned it off and looked at the instruction manual. When I turned it on again, everything worked apart from the screen. It stayed white and wouldnt change, sound and keys worked light worked but the screen stays white. Help I dont know what to do... I ordered it from in-digital on Ebay.
I have one Nokia e51. the problem is, when i turn on, the phone start but on the display i can't see nothing. i change the display with no result So the light from the display is working but the image...
does the phone still function normally otherwise? It sounds like what we call "the white screen of death." Basically, the wiring for the screen is shot but otherwise the phone is pefrectly fine. Very common on flip and slider phones.
Oct 06, 2010 | Cell Phones
White screen of death?
Hello
The white screen of death is a flex problem.
The flex of a phone is what connects the screen to the board of the phone. it is found in most flip and slide phones.
When you flip and slide these type of phones after a while the flex gets weak and that causes the white screen you see.
The only solution is to have your flex changed,that will definitely solve the problem..
Goodluck
Feb 19, 2010 | Motorola Mobility Rival A455 Cell Phone
White screen which keeps flashing problem
Hello and Welcome to FixYa!
Common problem know as WSOD (White Screen Of Death)
The only solution is to Flash the Firmware, BUT Note that when you turn your phone on, IF there is a pluse vibration (Just for a sec) THEN this solution will work.
The whole solution is well described in this article, again let me clear you it is a 100% working/tested solution, I'v done it successfully many time, but as you are a newbie, so throughly read the article before continueing and if you got any confusion, DO ask me here by posting a comment.
If I was helpful, kindly do Rate!
Regards, Waqar.
Oct 05, 2009 | Sony Ericsson W300 Cellular Phone
White screen on my phone
Its WSOD (White Screen of Death)
The Most Common Problem for SE-Walkman Phones.
There are tested/working ways to work it out.
You have to flash your Firmware, BUT read the full procedure first and ask me if you got any problem, before proceeding.
The Tutorial goes here
Note: This solution will ONLY work if your Phone shows a pulse of vibration when turned on.
Regards, Waqar.
Sep 23, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Kuxing k 1000 phone lock code written on the handbook it's wrong
if the code isnt 1122 then its been changed - if you've bought it from ebay you'll need to ask the ebay seller what they changed it to...
mopages.co.uk
Jul 20, 2009 | Cell Phones
White screen
I get the white screen of death as well from time to time and I found this video and it actually worked for me.
http://www.youtube.com/watch?v=a8g0sh7pc54
Hope you have the same problem as me and this should help out just do what he does:
When the screen goes white, let the music play, put it on hold, wait until the screen turns black then take it off hold and the screen should be back on hope this helps.
Jul 13, 2009 | Creative Labs Zen Digital Media Player
White Screen of Death?
Its you phone. you have to go to service center and ask to replace its fle or ribbon wire. 100% tested.. Thank you
Nov 13, 2008 | Samsung SCH-a870 Cellular Phone
Verizon LG Chocolate
You have the classic 'white screen of Death' Take it to your service provider. This is a manufactures defect!
Jul 13, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Nokia n70 white screen
nokia-n70-network-signal-problem
Jun 03, 2008 | Nokia N70 Cellular Phone
"White Screen of Death"
If you smash the phone with a hammer and then submerge it in a bucket of acid, the white screen will be gone
Oct 15, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
237 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
