SOURCE: Front loader f02 code
Check the entire length of the drain hose as well. This is from the bottom of the wash tub, to where it connects to the drain pump, to where it exits the washer to the standpipe. The two error codes can be directly related to each other. "F02" usually indicates a clog or failure of the drainage system. "Sud" can be caused from using too much, or improper detergent. It can also be caused when the drain pump is not functioning properly and is pumping air. If you have tried the "Rinse & Spin" option to clear the error, and you have verified all of your drainage system and still have a problem. It is recommended that you replace the drain pump. It may be running, but the impeller may be damaged and it is not pumping water properly. The following links may be of assistance to you:
http://www.fixya.com/support/r629564-suds_error_whirlpool_kenmore_front
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
You may have already viewed this information, but posted it just in case you may have overlooked anything.
If you determine you have a failed pump and which to replace it yourself, the following link explains how:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
If you require addtional assistance, please let me know. I hope you find this information helpful.
SOURCE: Lost my diamond wedding ring in washer. Where
it could get caught in the water pump or between the water pump and hose outlet, it could be caught between the agitator and the washing machine tub or it could be in the **** Trap in the wall, since it's heavier than water it would be the most likely place. and if not there then the over fill tub on the sides.
SOURCE: Won't drain
"F02" is a Long Drain error code. This indicates that you have an obstruction in the drainage system, as you well know by now. The following link explains:
I enclosed this information just in case you may have missed somethins. Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail. Also, check the connector plug on the pump to ensure it is making contact. It can come loose from vibration.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
In addition, the "SUD" error can occur in conjunction with a drain pump failure as this error occurs when too much air is sensed in the drainage system.
SOURCE: F02 code and SUD on occasion
If you check the drain pump reservoir and still experience problems, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, as well, and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well. When you open the pump reservoir, check the impeller to ensure all the blades are still intact.
It does not take much to damage these small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this can help you.
SOURCE: elite model #110.45862400 keeps
Remove the lower front panel.
Unscrew the drain filter and clean it out.
Replace the filter and run your machine.
