Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
Hoover Windtunnel shuts down after 15 minutes
My Hoover Windtunnel works fine for about 15 minutes and then shuts off. I thought I blew a fuse the first time, but it's the vacuum. Happens everytime I vacuum now. Plugging into different outlets makes no difference. It's just dead. Any ideas?
    President:
  • 1,124 Answers
Might be that its not exausting enough heat & stutting its self down..
Try cleaning all the filters & the hepa filter..
This will increase air flow & maybe fix the issue..
Hope this helps !!
rate me good ;o)
Posted on Jul 14, 2009
Why is it my vacuum cleaner keeps shuting off after ten minutes. i have a Hoover wind tunnel uh70086
Sounds like it has an overheat problem and is shutting down to protect itself. Make sure the exhaust filter is clean and that there are no blockages. Hoover UH70086 WindTunnel Cyclonic Pet Rewind Plus Upright Vacuum Parts...
Sep 17, 2015 | Hoover Vacuums
I was vacuuming with my Hoover Windtunnel Rewind t-series, and the vacuum simply stopped working. I plugged it into other outlets all around the house but no power suddenly.
Wait 30 minutes and try again, there is a thermal overload switch that resets itself.
Clean all three filters and see what happens.
Gary
Feb 23, 2011 | Hoover Vacuums
After running for 15 minutes, the windtunnel vacuum cleaner shuts off. It will not restart until it has been off for 30 minutes. Could it be overheating for some reason. All of the filters are clean;...
It's not necessarily overheating, but the thermal-fuse is definitely tripping and it takes 30 minutes to reset. There are several causes of this (in most common order):
1. A blockage in the suction system or a full dust tank
2. Dirty filters (Don't forget to check the air outflow filter at the back)
3. A worn belt
4. A faulty thermal fuse.
5. A faulty motor
As you've stated that the dust tank is empty and the filters are clean (don't forget to check the HEPA / air outflow filter at the rear), let's look at the other options.
Check the suction is good by putting your hand over the end of the hose and seeing if it will stay attached to you hand upside down.
Next, check the belt isn't slipping. Lie the hoover on it's side and check the rollers are turning constantly and at high speed. This isn't foolproof as it doesn't account for the extra friction of the brushes on the carpet, but it's a reasonable test. A worn belt wont necessarily be cracked. It can stretch and slip without cracking. Also, when a belt is slipping, you can usually smell burning rubber.
If the hoover runs ok for 15 minutes and there is no burning smell from the motor, then it's more likely a faulty thermal fuse than the motor itself. They are replaceable but unfortunately, thermal fuses aren't always sold separately and sometimes you have to buy a new motor (!!) to get a new fuse. Hoover are one of the best manufacturers when it comes to buying spares, so you might be in luck.
I've removed faulty thermal fuses from vacuums because a spare wasn't available without buying a motor. However, I have always done this with the owners full consent after explaining to them that a safety feature has been removed and they should avoid using the vacuum for prolonged periods without letting it cool. I also test the rest of the vacuum fully before returning it.
If you want to try removing yours, it will be attached to the motor with simple spade connections, but you do this AT YOUR OWN RISK. The danger in doing this is that the motor will burn out if it gets too hot, rather than being switched off by the fuse.
Oct 16, 2010 | Hoover U6630-900 WindTunnel Bagless...
Shark euro-pro x upright vacuum that shuts down every 15 minutes
These are prone to overheating. The manufacturer put a foam 'filter' wrap around the electric motor. This filter wrap insulates the motor, trapping heat inside, which causes overheating. The motor is very similar in form and function to the one in the Hoover Windtunnel, but the Windtunnel has no filter wrap. It doesn't overheat, and functions fine without it. There is a filter on the intake anyway. It's a redundant filter, and I have removed mine. It works fine now.
If you take the filter out yourself, you will need a special screwdriver for one of the motor cover screws. I guess they don't want the consumers opening it up.
I suggest taking it to a vacuum repair shop and explaining to them the problem, and asking them to remove the filter wrap from the motor.
Jan 11, 2010 | Euro-Pro UV209 Upright Vacuum
My hoover vacuum runs for about 10-15 minutes then the saftey feature shuts it off(overheat?). i have taking it apart a cleaned it with no results, added new bag also. after an hour it cools down and works...
Do you have suction through the tools? Does it look like it picks up when it runs? The machine could be clogged and that would cause the problem, but unfortunately the sensor that shuts the machine off could be bad if the machine isnt clogged. Its not easy to get to it, I'd take it to a repair shop.
Sep 16, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
Hoover windtunnel..runs fine for 5 minutes then stops?
OK - sounds like your machine has a blockage somewhere. Follow manufacturer's instructions for clearing blockages and all should be well. If you no longer have the manual, you can download it from the Hoover website.
Mar 08, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
633 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
