Model 25378126890 Should knob be on vent or closed while operating/ this is a window a/c This is a Sears product and first knob says closed or exhaust. Can.t find my manuel and haven.t used it for some time unit is working great on exhaust but is it correct?
    Problem Solver:
  • 5 Answers
The vent just lets fresh air in when the fan is running. either way is fine except very humid weather may effect the indoor air. i would close it during these times.
Posted on Jul 14, 2009
My vent knob to my window air conditioner is broken. Do i have to take apart the air conditioner to be able to fix the knob and also open and close the vent
Vent should be close when there is no smoke or bad smell in the room whenever you don't change vent knob you can close it manually. But first you must turn off its power supply to.make sure for safety reason
Jul 25, 2016 | Heating & Cooling
Do i have to open my window air conditioner to close my vent if the the vent knob is broken
Needn't ...its only required when room have some smoke or bad smell
The air will not blow out of the dash vents"why"?
need to re install vacuum line back to the vent knob so that it can direct the vacuum to a damper which opens and closes the air flow to your vents.this vacuum lose can also interfere with engine performance.
Jan 07, 2015 | Cars & Trucks
Where can i find a manual for craftman garge door?
Probably needs an adjustment. I would check Sears website as they have lots of info there for products they sell. An operators manual should give you this info.
Jul 21, 2014 | Sears Craftsman LiftMaster Chamberlain...
Hi I have a liftmaster garage door opener. It has been stopping alot during the opening and closing process. Nevertheless, it has continued to work. Now when I hit the main button on the wall,...
There are a couple of different models out there but they are all pretty much the same. Have you tried running the operator with the door being in manual mode? If you have not, push the wall button and see if the operator does anything.
If the operator runs fine without the door attached then try this:
Look for 2 blue tear drop shaped knobs, if you have a one light bulb or a 2 light bulb front and back those knobs will be on the back. If you have a 2 light bulb side to side, the knobs will be on the right side (right next to where the wires hook in to the operator). Turn the knobs slightly clockwise. The door should then move. If it moves more than it did but still stops, tweak them just a little at a time.
Let me know if this helps or not.
Sep 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
I can not get the temp knob to transfer form cool
most likely you'll have to replace the plastic tab on the back of your controls its easy to do. You'll have to take out the radio and temp. Control unit you'll see where the cable hooks in its probably broke. For a temporary fix you can unhook the cable at the floor. Its on the drivers side by the gas pedal.
Oct 20, 2009 | 2002 Nissan Altima
Haier HWR10XC6 Air Conditioner - Where's the "Vent"
the vent can be used to provided some quantity of fresh air,which is located betwen inner blower and outer fan blade. the operating knob is provided in the front panel.
Jun 02, 2009 | Heating & Cooling
Sears Wireless keypad will close door but will not open
If you are sure the battery is good than it sound like the keypad is bad and needs to be replaced. With a 6+ year old operator I would suggest a wired keyless entry (Donino GD-1) so if the operator has to be replaced you can use the same keyless entry.
Jul 04, 2008 | Sears Craftsman LiftMaster Chamberlain...
Oven vent
I talked to Sears Customer Service (who seemed to have heard of the problem) and they gave me Kenmore's number. The
There is no recall for the oven, but the person on the phone told me there was a design enhancement / adjustment that would stop the condensation on the back panel. The person I spoke with at Kenmore said there was a related product bulletin SF22-727 (for model 79095412102), but that that was only available to the technicians.
However, once the back panel is melted/yellow -then I think it needs replacing and I think that part costs about 100 in addition to the design adjustment.
I decided it was cheaper to buy a newer (used) oven than have the vent fixed/panel replaced.
Nov 01, 2007 | Kenmore 96422 / 96424 / 96429 Electric...
Heating & Cooling Logo
112 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
