Question about Garden
Ryobi line trimmer ry26921 will not continue running after taken out of start position changed gas and cleaned spark plug and filter cannot adjust air/fuel mixture recessed hex head screws because of special tool needed where do i get this adjustment tool
    President:
  • 1,129 Answers
Some times the carb diaphram gets weak and needs replacement while you are doing this spray it out with carb cleaner and blow out with compressed air, reassemble.
Posted on Jul 14, 2009
Ryobi weed eater stalls when giving it gas
check air filter and spark plug if good carb adjustment is needed or carb may be loose. could be bad fuel water in gas will cause this
Aug 26, 2012 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My Gas Powered Ryobi String Trimmer (RY26500B) won't start. What should I try??
Here are the basics. You need: spark, fuel, air, compression, and timing to make it run. Clean the spark plug. Inspect the fuel lines. Are the hard/brittle? Do they connect to the filter in the gas tank? Clean the air filter. When the spark plug is out, put your finger over the opening and gently pull the rope. Do you have compression?
Most common repairs needed are usually fuel lines and carburetor work.
Aug 20, 2010 | Ryobi Garden
I have a Ryobi brushcutter that is 4 years old.When I was using it the other day it just would not run at full throttle. I checked spark plug,air filter and fuel filter. No adjustments on carb. I have no...
Smokey 2 cycle oil will cause the exhaust ports to carbon up and plug the spark arrestor.
Remove the muffler, use a pick to clean out the exhaust port on the engine, and the muffler inside opening, then clean the spark arrestor screen, to assure yourself you are correcting the problem start the machine up with the muffler off, it should run like a charm, if it goes back to running badly when you reattach the muffler it may be clogged on the inside.
Jun 14, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Ryobi 720r trimmer starts ok but stalls when the
The carburator needs to be adjusted a little, thin our your mixture screw when the trimmer is warmed up and idling. Well how do you get it to idle? I usually have to play with the choke lever with the throttle wide open going from choke to partial choke as needed to keep it running. Adjusting can be tricky, you need a small screwdriver. Screw all the way in then back out 3 to 3.5 turns. this should get you close. Adjust idle as needed.
Jul 05, 2009 | Garden
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
Ryobi 780 Trimmer No Spark - won't start
Hi
Check the spark at the plug,compression and carburation.Clean the air and the fuel filters.Check the muffler.
best regards savumihai71
Sep 17, 2008 | Garden
Garden Logo
175 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
