Question about Intel PRO/Wireless 3945ABG Network Connection (WM3945AGMW1WB)
Computer - lenovo g530 w/ intel 5100 proset. router - linksys wrt160n. good signal but no connectivity. solution?
    Scholar:
  • 96 Answers
Try to remove Lenovo Readycomm. It usually does the trick.
Posted on Mar 28, 2010
Computer keeps dropping signal and now doesnt recognize signal
how far is your computer to the DSL wireless router? If it is too far and signal becomes to weak you won't be able to connect. And also make sure that there is no metal, concrete wall in between, it will block signal too. Good luck Thanks
Aug 15, 2011 | Linksys WRT160N Wireless Router
My ipod touch wont connect to linksys model number WRT160N
This router WRT160N has issues with the firmware. It is recommended that you should upgrade the firmware of the router. Download the correct firmware of your router from www.linksys.com/download .
save it on your computer. Is there any computer connected to the router ? If not then you will need to connect the computer to the router. Open the set up page of the router and upgrade the firmware of the router.
Once you upgrade the firmware of the router, reset the router and reconfigure the router.
Click here for step by step instructions.
Apr 05, 2010 | Linksys WRT160N Wireless Router
Dell Inspiron E1505- Intel(R) PROSet/Wireless 3945BG Network. I also have Comcast Cisco modem and cisco Linksys router. I was getting an error "problem applying profile". I went to the contorl...
I had usualy solved mysterious problems with other intel PRO wireless cards not authenticating, loosing signal, etc, by simply upgrading to the latest intel drivers.
Also using the Intel connection manager instead of the windows or Dell/other notebook manfucaturer's product is far more reliable.
Hope this helps.
Feb 09, 2010 | Intel PRO/Wireless 3945ABG Network...
No wireless connection
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Jan 27, 2010 | Linksys WRT160N Wireless Router
Wifi connection drops after it connects to the wifi
you can make sure your new laptop is on only the g band that should help, cos its trying to go on the n band which is causing it to drop.
Oct 10, 2009 | Linksys Wireless-G Broadband Router
Linksys wrt160N router inconsistant internet connection
Check on your cables makes sure they are inserted properly and the cord should be free of kinks, scrapes or loose connections......Also check the back of your computer make sure your ethernet card (the one that has the green lights/LED's) is seated properly (not loose)....
Good Luck.....hope this helps...if not let us know....cheers
Apr 13, 2009 | Linksys WRT160N Wireless Router
Linksys N router drops signal
Its not dropping you because of the spectrums, it works on line of sight. If you are in a basement and your router is upstairs it has to go thru a floor and the strength is weakened. Go into your router and increase the signal strength. But you have to mod your firmware.
http://www.coderetard.com/2008/05/30/install-dd-wrt-firmware-on-linksys-wrt150n-wrt160n-wireless-routers/
Here is a link to update your firmware.
Jan 24, 2009 | Linksys Wireless-N WRT150N Router
Ip Address 169.x.x.x Wireless Internet Connection Problems 6400/E1505 Dell Laptop
questions to ask yourself:
- I the wifi card connecting to the routers wifi network? or your next door neighbors?
- did it connect with the correct WEP? withouot the right WEP it will not communicatwith the WAP
- is the router set to be the DHCP server? this function is normally defaulted to ON
some times though windows simply has to have its TCP stack reset after having been connected to too many different networks, especially if you are a heavy wifi user.
open a command prompt: I see you already know how.
Type this command line
netsh int ip reset <anyfilenameyoulike>.txt
the txt file will be a log file tha will be placed on your main (c:) drive after the NETSH command has run
next lets reset winsock since we are here in the command line anyhow
netsh winsock reset
if everything goes right you'll be prompted to reboot you machine.
hopefully this will solve your inability to aquire an IP address from the router.
Jan 04, 2009 | Acer Aspire One PC Notebook
Device password????
Device ownership password:
Control Panel->add or remove programs-> Intel(R) PROSet/Wireless Software -> Modify -> Unmarked WI-FI PROTECTED SETUP
Dec 15, 2008 | Linksys WRT160N Wireless Router
Computers & Internet Logo
335 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
