Question about LG Heating & Cooling
Blinking red light... and does not air condition. the red light is blinking.. and it does not low air or cool. Fujitsu I. A . Q
    Top Expert:
  • LG Master
  • 76,070 Answers
The system charge is most likely low due to a leak or the thrermostat is defective, the blinking is a code, a repair person can access this code and its difinition and tell u the problem
Posted on Jul 14, 2009
FUJITSU Inverter wall mounted split air conditioner Model : AST12LSBCW not working, flashing lights
This is a "PFC circuit abnormal" in the outdoor unit meaning that the outdoor controller board is faulty. Try turning the machine off at the isolator switch for 10 mins, then back on to see if the error resets. If not you will need a new controller PCB.
Nov 15, 2016 | Fujitsu Heating & Cooling
Operation light is red and my Fujitsu split type air conditioner is drippy and icing up. model asu1201 serial AJA006007
Most likely low on refrigerant. This will cause the evaporator to ice up which will then drip in side the room as the outer surface melts. It also causes less air flow through the heat exchanger which exacerbates the problem. You need to find the source of the leak which is probably at one of the flare joins. Unfortunately, I don't have a service manual for this model so cant tell you what the error code is. Consult a local tech.
Jul 14, 2014 | Fujitsu 24C1 Air Conditioner
Fujitsu ASU18RLQ heater/air conditioner with 2 green and 7 red flashing error lights
Here is a link to the error codes.
http://www.fullyairconditioned.com.au/images/uploaded/files/fujitsu%20fault%20code%2
0split%20system.pdf
Hope you find an answer there.
Feb 15, 2013 | Fujitsu ASU18RLQ Single Zone Wall Ductless...
Toyota corolla 2003 air conditioning green light blinking and cold air not blowing
You've figured out by now the blinking light means the system has a problem. You'll need to find out if the system is low on freon or if a relay or electrical part is failing. The cooling fan could also be failing to come on, which would make the high side pressure exceed the limit and shut down the system.
Jun 24, 2012 | 2003 Toyota Corolla
Fujitsu AOU24CL - blinks twice - not cooling what does this mean? I can't find codes for this machine anywhere.
There are red green and yellow lights what is flashing, how many times is it on the controller ??
Sep 01, 2011 | Fujitsu 24C1 Air Conditioner
I have a fujitsu AOTR30LCT, when turned on the green timer light and the red power light blink 3 times. Only the fan works and does not cool.
Error c0de-3.Return air thermistor short circuit.
This sensor when it's defective, will not command for compressor for working.
Replace it.(Room air sensor). Helpful?
Jan 24, 2011 | Fujitsu Heating & Cooling
Fujitsu inverter; opens vents but no red light, no cold air
check that it is set to cooling sounds like it may be set to heat in cooling mode the indoor fan should at least run
Mar 10, 2010 | Heating & Cooling
Fujitsu asu24cl blinking lights
This machine is a looser. Mine has same blink codes. Its been serviced every year since it was installed 3-4 years ago.. Since the elctric work was half the cost of installing it, maybe Ill put in a differnt brand!
Aug 11, 2008 | Fujitsu 24C1 Air Conditioner
Error message
My plasma display the "error message condition 1" and red flashing light start blinking and TV screen shut down. Who can halp me to fix the problem??
Jul 03, 2008 | Fujitsu Plasmavision PDS-4221 42 in....
Heating & Cooling Logo
208 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
