Question about Goodman CKL42AR42 Air Conditioner
Hello, I have a Trane blower motor that want start. I am getting 24vts to the outside unit but the indoor not responding. Also getting 120vts........however im gearing towards the circuit board to be replaced... any thoughts before i buy this board? please help
  • 86 Answers
Are you getting 120v at the "cool" terminal on the board try taking one of the motor leads and hooking it up to the 110v going into the control board if that works check to see if you have 24v at the "G" terminal if you have 24v at "G" and no voltage coming off of "Heat Or COOL" then i would replace the board
Posted on Jul 14, 2009
Trane xl80 blower working intermittently
hello Miss/Mrs/Mr,
I have the furnace trane xl 80, when I turned for heat everything working but only blower motor was not running, I wait for 1 minute all system suck down? I guess the capacitor blow out, that the reason why blower motor was not running
Please email me that is the
Jun 24, 2012 | Heating & Cooling
I have a coleman outdoor split system the indoor unit has two cooper pipes at the bottom the larger one keeps forming ice around it.
Hello my name is Heath it will be my pleasure to assist you. First thing to do is turn the unit off and check the filter then if the filter is okay check to see if the blower comes on when you put the fan switch on the thermostat from auto to on. If the blower isn't coming on then there could be a problem with the blower motor. If the motor is running then turn the system to cool and turn the setting down to where the air should be on. Then check the outside unit and be sure the outside unit is running if the outside unit is not running go to the house panel box and check the breaker to see if any of them are tripped or off. If there off turn them on and check the outside unit again. If all is running and you get no air flow through the vents then the coil could be frozen. If the unit is frozen turn the thermostat to off and leave the indoor blower on by leaving the fan switch in the on position for a couple hours till it thaws. If the unit froze up then there could be a problem with the a/c system most likely low on refrigerant as a result of a leak. I would have it leak tested and repaired if this is the case.
Aug 27, 2011 | Coleman Heating & Cooling
The line coming into my indoor unit gets iced up. The ice extends the length of the line out to where in connects to the outside unit.
Icing in door due to 1. Less rpm of indoor fan motor (Replace capacitor or motor). 2. Indoor coil and blower wheel, filter dust blocked. (Service the unit). 3. Short of gas. ( Find for leak and arrest. Then vacumise and do gas charging)
Dec 24, 2010 | LG LS122CE Split System Air Conditioner
Trane xe 1000 - 1/4 fan motor went bad - I replaced it with a used 1/3 from another trane unit - it had same wiring harness etc everything starts, runs, cools -cold air - but only for about 5...
Did the 2 fans have the same rpm. If there is not enough airflow through the outside unit the compressor will shutdown on high discharge pressure. Also make sure the fan blades are positioned right if there is a shroud for them. Did the other motor have a capacitor with it or did you use the 1 from the smaller motor. Sometimes the motor data plate will tell you what size capacitor you need. Let me know what you find.
Aug 24, 2010 | Heating & Cooling
Blower turns off after outside unit starts up??
If this is a standard split system, the indoor blower should not shut off after the system starts, it should only shut down after the room has reached the set temperature.
Since the blower seems to be starting, when the outdoor unit does, "correct?", the control system seems to be working properly, so the next step is to look at the motor itself, it sounds like it is getting hot and shutting off. This can be verified by waiting for it to shut off, turn off the power and then carefully feel the motor. If it is very hot, you have a bad motor, or a loose wire to the motor, also a bad capacitor can cause problems also, but in my experience, if it is a bad capacitor, the motor will not start at all.
If this has been helpful, please rate the new guy :)
If you can get me some more information, I can help you further.
Have a great day.
Sincerely,
Paul Gibson
Apr 04, 2010 | Carrier 38CKC036 Air Conditioner
How to Clean 1984 TRANE Cooling VENTS inside house No Manuals
The Outdoor unit will be easy 1st diconeect power at panel, or disconnect box near unit. Remove top of unit, be careful not to damage fan blades. Spray coils (fins) with a light degreaser let is soak for 5 mins. wash out coils from inside the unit out. Spray straight on so you push the dirt out the other side.
Re assemble and start up.
Indoor coil will be accessed by removing front cover and you may have another cover to expose the inside of the coil fins. That is where you need to clean. Spray degreaser on coils and rinse off. If its gunked up then use a wire brush 1st. Carefull not to bend the fins over.
Check the drain pan at bottom of the coil to be sure it's not full of stuff. Blow out if needed.
You should be clean and ready for the season
Jul 02, 2009 | Ruud Central System Air Conditioner
Goodman CKL42AR42 Air Conditioner Logo
318 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
