Question about Garden
When my yard machine tiller goes from choke to run it it dies out what could be the problem
    President:
  • 1,129 Answers
The carb float bowl needs to be taken off (1'2 inch bolt on bottom of carb) and float bowl cleaned out usually you will find debree and water in there reinstall the float bowl if this doesn't do it remove the carb, disassemble, and soak or spray wiith carb cleaner the blow out passages with compressed air. Reassemble without bending float tab.
Posted on Jul 14, 2009
MTD lawn tractor will start but dies after 3 seconds no matter where speed control is moved or left, choke adjusted, etc. First starting after 5 months.
If your fuel valve fully ON? Is there dirt in the tank? Is the filter clean? These are the the first things you should check.
Apr 30, 2011 | Mtd Products Yard Machines 158CC Tiller
I cannot remember how to start my tiller
This Could be a problem? Turn the fuel on, place throttle lever to choke, prime if available and pull cord. when running move throttle to run. Good Luck, your gonna need some!!!!
Apr 20, 2011 | Mtd Products Yard Machines 158CC Tiller
Will run with full choke on but once i turn choke off it dies
The carb jets are clogged, it will have to be removed and soaked in carb cleaner. Sometimes that will not work either, and the carb will have to be replaced. Reason is, some of the carb passages are as fine as a human hair, so it's hard to get gunk and bad/dried gas deposits out.
You could try running something called Sea Foam (mixed in the gas)from Walmart through the tiller for a while, that MAY help somewhat.
May 23, 2010 | Mantis 2-Cycle Tiller
My troybuilt yard pony riding lawnmower will start with the choke fully open and then dies immediatly when you take the choke off. It will only start and run with the choke fully open, but dies after 20-30...
Do you mean that you can start it normally using the choke (that would be choke CLOSED), but then it dies immediately when you move it to run (that would be choke OPEN)? And if you leave the choke in the starting position that it dies after 20-30 seconds?----- If I have that all right, then you definitely have a restriction in the gas supply. Drain all of the gas from the mower and don't use any old gas. If you have any more old gas (from last season) don't use it. If this mower has a gas filter, replace it. Put just a little fresh gas in the tank plus a little of the cleaner. Start it up, do that a few times if needed. Use a fuel additive such as Sea Foam to keep the gas from gumming up so fast.
Mar 15, 2010 | Troy-Bilt Garden
Yard Machine 20HP TWIN runs but when you take off choke it Dies!
remove carb and clean the main fueljet
it is gummed up due to set to long with
gas in it.
Aug 04, 2009 | Garden
I have a yard machines rear tine tiller with a 5.5hp b/s engine. its able to start time and time again w/ full choke and throttle but dies out
You need to rebuild the carborateur, it sounds like the diaphragm has played out, when you must use the choke to pull the gas through the carborateur
Jun 15, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Tiller won't stay running
If you choke or prime the engine, it starts up for a second or two and dies, the carburetor need to be cleaned/repaired.
May 25, 2009 | Mtd Products Yard Machines 158CC Tiller
Garden Logo
104 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
