Monitor randomly turned itself off.. now won't turn on
LG Flatron l196wtq-bf monitor goes into ''power saving mode'' now won't turn on at all.. bought a new monitor, it is fine. Still no idea what is wrong with the old one :(
The problem is with the owner, useless piece of ****.
Posted on Sep 24, 2009
  • 1,684 Answers
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 19, 2009
Flatron W2353 monitor wont turn on
LG W2353 dvi power saving mode
how to fix ?
Dec 22, 2012 | LG FLATRON W2353V 23 inch LCD Monitor
Lg 1752s goes into power saving mode when pc is turned on
Hello Alan,
That is actually not power saving mode, the flashing power light indicates the power supply is not starting up correctly and keeps shutting down and trying again. This is a very common symptom of a failure of the capacitors on the power supply board. The L1752s uses the AIP0157 power supply board which is the same board the is used in several LG monitors such as the L196WTQ and L194WT. Here is a link to a repair guide for the L196WTQ that shows what capacitors to look for and replace on the power supply board to bring the unit back to life.
http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/
BuddyMc
May 15, 2012 | LG L1915S 19" LCD Monitor
How do i dismantle L192WS LG monitor ? please help
We have a full disassembly and repair guide for this model monitor posted on our site at:
I hope this helps, if so please rate our solution.
BuddyMc
Jan 01, 2011 | LG L196WTQ-BF 19" Monitor
My monitor, Flatron L196WTQ-BF, just quit working one day. I have tried to get it to work, checking power, moving to different computers, etc, but it won't light up at all. The on/off switch remains dark...
It sounds like you have a failure in the power supply board. We have a free repair guide posted on our site at: http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/ that should get you back going again. The guide shows you how to remove the case and what to look for to identify the problem. Look it over and see.
CCL_Tech
Corporate Computer
www.ccl-la.com
Sep 04, 2010 | LG L196WTQ Monitor
LG L196WTQ monitor just quit working. won't turn
Look in the power supply section first for bad caps, post back what you find inside, pictures will help a lot to guide you through, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 24, 2010 | LG L196WTQ Monitor
LG Flatron L196WTQ-BF Monitor will not power on
Here is a link to a How To on this monitor (and similar) they offer cheap parts as well.
http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/comment-page-1/#comment-136
Nov 12, 2009 | Computers & Internet
Monitor goes into power saving mode. How do I
Go to desktop properties>screen saver option>power option & select the turn off monitor never.
Oct 15, 2009 | LG Flatron L1718S LCD Monitor
Monitor keeps shutting down into power save mode? Its a LG Flatron L1932TQ-BF. Turn it off then back on it comes on for a breif second then shuts down again?
This happens when the capacitors (680uf/25v & 1000uf/16v) on power supply board are blown.
Please locate an LG service center close to you by following this link
Oct 05, 2009 | LG Computers & Internet
Flatron LG monitor safe mode
Your monitor goes to Power Saving Mode when the signal it is receiving is not correct. In all probability this is not a problem of the monitor itself, rather you should check the connections and the computer the monitor it's connected to. For example you could try a different RGB cable and try it in a different computer.
Apr 13, 2007 | LG Flatron L1951S 19" LCD Flat Panel...
Computers & Internet Logo
395 people viewed this question
David Payne
David Payne
