Cars & Trucks Logo
A
Anonymous Posted on Dec 19, 2015
I have a 4.9l engine surges at idle running way to rich and miss. at higher rpms .I changed fuel filter spark plugs . what can it be?
paulmacintyre
Level 3:
  • Cars & Trucks Master 3,218 Answers
  • Posted on Dec 19, 2015
paulmacintyre
Level 3:
Answers
3218
Questions
0
Helped
966663
Points
11418
How do you know it is running rich? The computer controls fuel delivery. If it is running rich, one or more sensors may be giving the computer false readings resulting in a rich mixture. A leaking fuel pressure regulator internally will also cause a rich issue as well as a stuck open EGR valve. A scan test monitoring engine data can inform you of what may be the trouble
Testimonial: "I changed fuel pressure regulator the exhust is very strong black"
  • Anonymous Dec 19, 2015
    thanks its so rich it runs you right out of the garge. ill try fuel reg. hope for the best ..
1helpful
92 toyota pu surges in high gear
High gear strains the engine more than others, so any tune up item could cause this. Leaking vacuum line, bad air flow sensor, clogged converter or muffler, weak fuel pump or dirty fuel filter all can cause this. I have also seen rust in fuel tank go right through filters and make metallic deposits on spark plugs which will then miss at high speed first and soon at all speeds. Try pulling plugs and "reading" them first. Then test fuel pressure while running at high RPMS.
1991 Bronco 5.0 engine will not start unless the gas pedal is pressed about half way down even then hard to start once running engine idles about 200 rpms past normal if you shut engine off you must repeat...
Change the air filter.
Check the Throttle position sensor and make sure there is no recall on the intake manifold.
- I had a Ford Taurus with the 3L V-6 that had an intake manifold issue similar to what you describe. The butterfly in the intake had excessive wear and would stick in a different position causing the car to idle at 1800 rpm. The "fix" was to change the intake manifold.
Also, change fuel filter, spark plugs and check distributor cap / rotor and plug wires.
Its definitely running rich (exhaust smell). With no CEL I would say its a mechanical issue more than an electrical issue but you cannot rule ANYTHING out based on description. May want to entertain the idea of plugged cats too.
GOOD LUCK !!!
Idling #5 and #7 miss fire. holding it at 2000 rpms makes all 8 miss fire. its running really rich and the only code its showing is P0300 which is engine miss fire. have replaced plugs wires cap and...
When there is an engine misfire it could be gas or spark related. Or, the oxygen sensor may not be operating correctly, which controls fuel supply.
If there is a 'random misfire' then it could be an oxygen sensor causing the problem, as well, causing a rich mixture.
Good luck on this repair.
Drops rpms and wants too die . could it be a feul
adjust the idle, check the carburator system...., also check the battery and alternator.
4helpful
3answers
2001 ford focus had the spark plugs and wire change. Has a code po171.. ran good for two days. The spark plugs are blacker than acs of spades which is running rich. Don't know what to do next. To me its...
PO171-System to Lean (Bank 1)
Air filter cover tight?
All intake ducting tight?
Clean MAF Sensor.--CRC MAF Cleaner
Fuel Pressure Regulator?
EVAP Purge Valve-stuck open?
Vacuum leaks?
EGR System-issues?
Seems your getting a lean O2 Code,because it is trying to correct for a rich condition,as you said.
Is the Throttle Position Sensor-original?
Work on what is driving it rich,my list is a possible.
1988 5 speed Honda Accord
Ensure your spark plugs,wires (ignition coil and spark) and your filters (air and fuel) are within 2 years of installation It's erratic at 800 rpm as the engine is cold and they like the 2200 range for 3 minutes before they kick down on their own. Press the pedal twice before inserting your key. The owners manual states depending on the outside temperature, the engine will require more priming. Update if possible.
Rich fuel smell in & out of car, causes my eyes to burn.
You changed everything but the temperature sending unit/sensor. That's what is your problem as far as no proper cold start. When first started and cold, the sensor tells the computer to place the engine into cold start mode, engine starts and runs because it's at a bit higher idle and getting a bit more fuel. When warmed up, the sensor, if good, will tell the computer to place the engine into normal run mode now. Have the sensor tested first. If good, the engine is not going into a higher idle and is still getting the fuel but not using it fast enough because it's flooding. Hence the fuel smell. That's the fast idle solenoid on the EFI for this and the A/C high idle when it's running.
Truck stalls
if it is burning rich, there for it will be over fueling around low rpm i do belive, which will cause the engine to flood, im guessing after you have been low rpm then go for high rpms, it like hesitaes and takes abit of a cough then goes, if that is the case then it is overfueling.
there is a way to advance/****** the engine mixture, but id say for safe if you don't know what your doing to take it do a garage, and ask for it to be timed up with the timing strobe light :) which will stop the, over fuelling around low rpms.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
