Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
I have a leek on white screw thread above motor on my dream maker 500 spa and I can not stop it leaking. it comes out above the top not on the bottom screw thread side. Can you help
    Habit-Forming:
  • 77 Answers
You probably only need a new union o-ring and it's a simple fix.
Regards,
Ian.
http://hottub.synthasite.com
Posted on May 22, 2010
Jets are not working
Your motor may be locked up or you may have a bad starting compasitor. Remove the cap on the back of the motor and see if you can spin it freely. If so check the compasitor. (a black plastic one will have a small cut out where the wires go. If it's black or blown out it's bad. A silver one will bubble out at the ends. If you can't tell set it on a table, flat bottom down, if it rocks it's bad. It should sit flat) If the motor doesn't spin freely pull the pump out and take the wet end off of it. Once the wet is removed if it spins freely your motors fine and you need to replace the seal and more than likely the impeller you just pulled off that has a split shaft.... This is caused by a pump seal leak going unchecked.
Sep 17, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker Spas leak
This means one of your top jets is leaking. Firstly try Fix A Leak this will stop any leak up to an 1/8". If this does not help there will be more difficult work in store.
Each jet sits in a jet body, these jet bodies are behind the tubs shell, you'll need to get in behind them to see which one is leaking. This can be difficult as they are often covered in insulation foam.
Sep 05, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a dreamaker 8003 xspa that has worked perfectly over the many years that I have had it. The other day I noticed that the water had lowered 6 inches overnight an the water was coming out of the
1. Check equipment like pump, heater, blower, light fixture, for leaks.
2. Remove side panels closest to the are the leak is showing and inspect jets, plumbing in that area for leaks. If insulation is foam, remove any water saturated foam and follow it to the source of leak.
3. If the leak is in plumbing and is very slow, sometimes it can be resolved with "stop leak" products.
Aug 07, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker x-500 5 person developed cracks in the shell of the 2 corner seats, nearest the access panel. It appears the seat supports molded to the base of the spa are pushing the seat bottoms upwards,...
If it's loosing water this should be a structure warranty. I have two of these and had to drain the spa and shine a light in the spa and take pictures from underneath. Then the light will show off the cracks well. If your the original owner just keep at Dream maker, they should give you a new one.
Dec 11, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
My brother in law is moving so he gave us his spa, why is the motor so loud?
Could be the bearings are going bad. Nothing comes for free. That's pretty cheap for a dream Maker though.
Sep 09, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
There is a leak on my 4 person Dream Maker hot tub at the pumps connection to the other plumbing. I'm wondering if it needs a new gasket or what? The leak is taking out a couple inches every couple days....
From your description it sounds as though the wet end faceplate gasket needs replacing. Where are you from? If you're from the UK I may be able to help you. Feel free to contact me: http://hotub.synthasite.com
Regards,
Ian.
Mar 19, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
How do you replace a flow switch in a spa, or hot tub
turn off the power to the spa. remove the cabinet under the topside remote to expose the equipment compartment. You should see the flow switch, it's usually a threaded 3/4" plug with a single grey wire coming out of it. Most of them are threaded into a tee or a special transparent fitting. If the water level in the spa is above the flow switch, you may have to drain the spa down unless you're very fast about getting the new switch in. Unthread the old switch and thread the new one in. Follow the wire on the old one to the spa pack. You'll have to remove the screws on the cover to expose the circuit board. Follow that wire into the spa pack to see where on the circuit board that it is plugged in. It may be good to run the new wire to have in place as soon as you unplug the old one you can install the new one with no question as to where it plugs in.
Reinstall the cover on the spa-pack and turn the main power back on. Make sure that the arrows on the new flow switch are facing the correct direction (direction of flow). Once you have the spa on and it starts back up, run everything to check for leaks and proper operation. If the flow switch was the only problem, all your faults should be cleared and you should be in good shape. If there are no leaks, you can reinstall the cabinet panel.
The new switch should already have teflon tape on the threads, if not, use teflon tape, apply the tape in the direction as if you were threading a nut onto the threads. You only need a few wraps of teflon tape, too much can crack the fitting you threat the new flow switch in to.
Nov 03, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
How do you replace jets on dream maker spa X-500
There is a tool that comes with the spa, instructions are in the owners manual. If you don't have the manual you can download it here
http://www.dreammakerspas.com/_PDFs/0607l.pdf
If you don't have the tool you can order one from Dream Maker.
Oct 19, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
407 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
