Question about Kenmore 92320 / 92321 / 92322 / 92324 Electric Kitchen Range
No power Makes buzzing noise when turn knobs, burners and stove do not work
  • 867 Answers
There is a electrical fault, like a short, it seems to have shut down for safety reasons, call repairman
Posted on Jul 14, 2009
My oven wont turn off from the knob it keeps turning
You didn't say whether you have a gas or electric oven, or oven & stove. I'll assume you have a stove, just to cover all bases.
First, you should shut down the oven: a gas stove will have a valve on the gas line behind the stove. The valve will either have a red handle or a flat stem that usually has a hole in it. Turn either valve 1/4 turn to shut off gas, use a wrench on the flat stem. An electric stove should be shut off by flipping off the double circuit breaker for it in your electric panel. Do not unplug an electric stove when it is on; this can damage the plug &/or electrocute you.
Most likely the inside of the knob has stripped out. Look at the knob for a hole that has a setscrew in it: a small allen wrench or screwdriver will loosen the setscrew, most knobs don't have them and will pull off. Be careful to use even pressure on two sides of the knob; if you can't pull it off, use two butter knives or flat screw drivers to pry it up enough to get a grip on it.
Look at the center stem on the back of the knob, it will likely be cracked or stripped. Some stems have a D-shaped metal insert that strips out inside the plastic stem. If you have one, pull off a burner knob and compare the stems in the back, if they are the same size, put the burner knob on the shaft for the oven control, and use that knob to turn the oven control off.
If the burner knob won't fit, use your fingers or a pair of pliers (gently) to turn off the oven control shaft. If the shaft stops normally, you can turn the stove back on using either the gas valve or the circuit breaker. If you have a gas stove that doesn't have electric ignition (a clicking noise when you turn on a burner) you may need to re-light the pilots for the burners. Lift the covers off the burners to re-light the pilots.
If you have succeeded in turning off the oven, you need a new knob -- you can get one at an appliance parts store or maybe a hardware store. If the oven control did not turn off normally, I would leave the oven/stove turned off: the control itself will need to be replaced by a qualified repair person.
Mar 03, 2013 | Ovens
Humming noise from stove
Turn the convection oven switch to the off position.
Feb 15, 2010 | Viking Stove/Oven/Range Timer Knob -...
My gas stove is clicking all burners are off
There are switches behind all of the knobs that activate the "sparker" when you turn them. Any one of these will spark all 4 burners. Sounds like you have a bad switch that has stuck in the "on" position. Experience tells me to replace all 4 switches - when one goes, then the others aren't too far behind. Get the part number off the switch and google it. Not too expensive. Until you get them replaced, just unplug the stove and light with a match - remember that the oven will not operate without power cause it has a different igniton system.
Sep 06, 2009 | Magic Chef Kitchen Ranges
Gas stove makes clicking noise when turning on
When a gas stove is clicking, it means it is trying to ignite the burner. If the knob is held in the ignite position for more then 3 seconds and the burner does not ignite, it means that (1) the gas is shut off to the stove, (2) she does not have gas service set-up yet at the apartment, or (3) the gas nozzles feeding the burner are dirty and clogged.
Most of the time, when you move to a new apartment, you need to call the gas company and have the gas turned on, unless it is included in your rent. Either way, when a house or apartment is unoccupied, the gas is turned off for safety reasons. I would contact the landlord to be sure.
Mar 22, 2009 | Stoves 600SiDOm Gas Kitchen Range
Clicking sound on my gas stove
You just need to turn the knob a bit more, thats the igniter you are hearing.
Mar 17, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Stove Top won't heat
clock works because its only 110 volts.all else is 220.as a repair man the firstplace i would check is the cord.[power off]why there first the installers dont know how important it is for those cord screws to be very tight.consequintly the leave them looseish,and thats where they burn.if thats ok.make sure you have 220 there at the cord.God bless you,tom
Jan 02, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Super Capacity 465 Gas Range
my gas stove top burner will not ingnite when I turn on the gas.
I have gas supply to the house, the gas stove top makes the tick tick noise when you
turn one of the burners on, but no flame, even if you try using a match.
What all can I checK?
Sep 20, 2008 | Kitchen Ranges
Range burners
There must be a problem in one of the switches which is behind one of the knobs. Will have to check each switch with a meter.
Oct 03, 2007 | Tappan TGFS_63 Gas Kitchen Range
Kenmore 92320 / 92321 / 92322 / 92324 Electric Kitchen Range Logo
142 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
