Question about Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop
Dell E510 has a solid amber light, no light codes or sound codes. Unit powers up but will not boot. I unplugged and replugged all the wires to no avail. Does anyone have a clue as to why?
    Scholar:
  • 56 Answers
Contact dell technical support for a replacement motherboard. If I remember correctly this model had a recall due to faulty capicitors and should be replaced even if you are not under the service agreement still.
Posted on Jul 14, 2009
How do I fix a dimension E510 with a solid amber power light?
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 25, 2014 | Dell Dimension E510 PC Desktop
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
I've got a Dell Dimension 5150. After connecting to the mains the power light is blinking amber for some time, it then disappears and only then the computer can be booted. Unfortunately this delay is...
Check POST Boot messages for a flat Battery; Check Front control panel circuit over (remove); Check other USB connectors; Try a replacement Power Supply Unit.
Sep 12, 2010 | Dell Dimension E510 Dual Core 2.8 Ghz...
Tower power button flashes amber but will not start
Flashing Amber power LED indicates a bad power supply.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817822008&cm_re=atx_power_supply-_-17-822-008-_-Product
May 13, 2010 | Dell Dimension™ E510 PC Desktop
Solid amber light ON Dell Inspiron 530 desktop.The Fans start and stop immediately.The mother board has the power ON Amber light.
The Yellow Light of Death, anyway turn on Your PC, as it starts You will here some beeps especially on a Dells. Count the beeps , there will be a slight pause so it will beep once then pause then beep again. Count the beeps and that will be Your code. Go to Dell Support site and look up code. Most of the time a Yellow amber light means that there is trouble with Your Motherboard but thats not to say its the Motherboard itself, it could have possibly burned out Your RAM, Processor, Heat fan, even the power supply itself. So look up the code and at least You'll have a better chance of finding the solution, Good Luck
Mar 04, 2010 | Dell Inspiron 530 Desktop Computer
Blinking amber light and wont boot up.
if the power button was blinking amber, unplug your tower, and hold the power button for 30 seconds to 1 minute, to use any excess power stored in the capassitors in the pc. this was told to me by a dell tech, it is a small issue with the 3100=E310, and 5150=E510 Dimension desktops
Sep 24, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Steady amber Power light
You are looking at a new mother board. I would take it to a certified technician shop, so they can run a stress test on the motherboard for final benidiction.
Aug 13, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Amber light flashing on dell e510 won't power up
Try reseating the memory sticks.
2. Remove 1 - try to boot
Jun 18, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Boot up problem
Unplug all the Harddrives, Cd Drives attached to the motherborad. Try turning up the system. If it boots, you may to have to change the I/O cables.
Still if it is amber, then your motherboard is having the problem with. As long as the LED glows PCU gotta be okay.
Kindly get back for futher help
Jan 09, 2009 | Dell Dimension E510 PC Desktop
Sold amber light/fan running
Hi, Does the system makes any beeping sound? Does it go to the boot up stage, which can be seen on the screen. Provide the model number with your reply. Thanks, Mike
Nov 01, 2008 | Computers & Internet
Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop Logo
1,720 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
