Washer not completing the cycle
I have a Kenmore washer and I've had it for about 8 or 9 years. It still looks like new. I am the only one using the washer, so I use it sparingly. I don't pile clothes in and I make sure everything is even. Just yesterday I found out that it stops at the rinse cycle and will not move. I've tried starting the cycle over and watched it, once it got to the middle portion of the first rinse cycle it stopped. Never went to spin. I tried starting it again at the first rinse cycle and it just sat there. I tried starting on the spin cycle and it made some noise like it was trying to start but didn't. I can't afford a new washer and repairs are very costly. Is there anything I can try that I haven't already tried? I had one dress in the washer and on the lowest level of water, I also used the delicate cycle. HELP! HELP! HELP! I don't have the model number since I am at work, however it is a Kenmore as I mentioned above.
hurricaneC
  • hurricanec4m Jul 15, 2009
    The Washer was purchased in 2000. It is not a brand spanking new washer, however, it shouldn't quit on me soooooo soon. I am pissed because I don't use it that much and I feel that I should be shutting down before my washer does. I'm older than that washer.
    Thanks for responding.
    hurricane
  • yadayada
    yadayada May 11, 2010
    looking new and being new are 2 very diff things.
  • 975 Answers
OK , try this , open washer and check out the DRAIN MOTOR PUMP located at the bottom on the side (its got like a little fan on it) , take it out and remove any debris & lint , it could be clogged , hope it helps , AJ
Posted on Jul 14, 2009
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
My Kenmore washer drains after the rinse cycle but won't spin at the end of it's cycle. If I manually set it to the spin cycle, it spins just fine. Desperate!!! The lid switch was just replaced about
Possible there is problem with the timer controller unit. It seems that the stepper motor is not moving to the next cycle until you manually move it to the spin. You can use some contact cleaners on the switch and also carefully try to see if the timer moves within , replacement is a costly issue and must be debated
Nov 20, 2013 | Washing Machines
I have a kenmore elite HE3 washer. I was getting the sud error and then eventually F02. I cleaned out all the drain lines and pump filter trap and this did not help. I've now replaced the pump
I endevor to purchase a new unit. I've had the same electrical issue with the "F" variable coming up for EACH cycle. I've pressed the Pause/Cancel button and attempted to resume the cycle. While that did work, again, the "F" would come up and the cycle disrupted. I think I will end up paying quite a bit to have it serviced. My washer is 7 years old and I've had it serviced twice to date. I intend on purchasing new in the New Year, a Samsung or LG.
Nov 24, 2012 | Kenmore Elite HE5t Washer
I have the Kenmore front load washer HE2. How do I use the clean washer cycle.
Hello, welcome to FixYa.
In order to perform a "clean" on the HE2 is as follows...Read these instructions completely before beginning the cleaning process.
**If necessary, the cleaning cycle may be interrupted by pressing STOP. This will stop the cycle. A RINSE/SPIN cycle must then be run to thoroughly rinse the remaining bleach from the unit. Failure to do so will cause damage to the unit and clothing added to the next cycle.**
Begin procedure
1) Open the washer door and remove any clothing or items from the washer.
2) Be sure the door is closed.
3) Open the dispenser drawer and immediately add 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment.
NOTE: Do not add any detergent to this cycle. Use of more than 2/3 cup (160 mL) of bleach will cause product damage over time.
4) Be sure dispenser drawer is closed.
5) Select the CLEAN WASHER cycle.
6) Press START.
NOTE: The basket will rotate, then the door will unlock, lock again, and then the cycle will continue. The machine will not fill, but the basket will rotate while the washer runs a short sensing cycle. This will take approximately 3 minutes.
7) The cycle will determine if clothing or other items are in the washer. a) If no items are detected in the washer, it will proceed to step 8. b) If any items are detected in the washer, all cycle lights will flash and "rL" or "F/34" will be displayed. Associated LED status lights will remain lit. The door will then unlock. Press STOP to cancel the failure code. Then repeat steps 1, 2 and 6 to start the cycle again.
8) Once the cycle has begun, allow the cycle to be completed.
9) After the cycle is complete, leave the door open, slightly, to allow for better ventilation and drying of washer interior.
Good Luck and thank you for choosing FixYa. Please take a moment to rate the info I provided and a short testimony is appreciated.
Regards,
Macmarkus :)
Aug 14, 2011 | Kenmore HE2 Plus Front Load Washer
We bought a kenmore front loading heavy duty washing machine with 2-way tumble in Feb 2003. Recently two problems have become evident. First, our clothes have started to have black marks (streaks and...
Likely the cause is grease from a failing rear bearing.
Unfortunately, it's cheaper to buy a new washer than to fix this one. That's pathetic for a washer that's only 8 years old, and completely negates any environmental and economic benefits of buying a front loader.
Jan 29, 2011 | Kenmore 44102 Front Load Washer
After spin cycle is complete, clothes in washer are still too wet
Check for obstructions in the pump and discharge hose. Check the motor coupler. Here is a video that should help.
http://appliancehelponline.com/topdirectdrivevideo.html
Jun 04, 2010 | Kenmore 22422 Top Load Washer
The washer on my double stack won't drain or spin.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Without a complete model number, I'm guessing but usually, washers have a lid lock built in that prevents the washer from draining or spinning unless the lid is closed.
If the lid lock is defective, the washer probably won't go into spin mode.
Check yours for the lock, where it attaches and replace it. It's probably not too expensive.
Oct 27, 2009 | Kenmore Washing Machines
Kenmore 92274800 repair ... WONT SPIN
My 110.92274800 did the same thing 1hr ago. Ive isolated the Problem it is a 15.49 cent problem from the manufacturer's website Part # 285753A. I am going to order and try and tackle the problem myself unless i can find it at a local Appliance Center that has it on Monday. Will keep you informed. Doesn't look to Hard. if you lean your Washer forward you will probably find 1/8 inch white peg looking plastic pieces. assuming you can hear the motor running on the spin cycle. You may lean the unit forward put it on spin and look at the motor to make sure it is still in operation. Hope this helps
Jan 03, 2009 | Kenmore Washing Machines
Kenmore Front load washer didn't complete the cycle.model #44082
Do you still have your owner's manual that came with the Kenmore washer? Look under troubleshooting your Kenmore washer.
Jul 06, 2017 | Kenmore 44102 Front Load Washer
How to work my washer?
the timer change by itself. You don't have to change anything.
But cold rinse only works if you have the cold water connect to the washer
May 08, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
