Question about Refrigerators
Side by side fridge #ED5FGHXKQ03 is getting warm and sometimes even hot, on the outside around doors and neither sides are cooling and freezing properly.
  • 39 Answers
Make sure your condenser coil is clean.then pull refrig out,remove cardboard panel and check for condenser fan motor opperation.if motor is stuck, then replace it. be careful it could be very hot.
Posted on Jul 15, 2009
Whirlpool model et18tk and the side of the fridge gets hot? It it junk?
This is normal unless the refrigerator is not cooling properly. There is a pipe that goes around the door that carries hot Freon to keep the doors from sweating where the cold inside meets the warm air outside. This area will become extremely hot should the airflow below the refrigerator become obstructed or the condenser fan below the refrigerator not be working properly
APPLIANCE 911
Aug 15, 2016 | Whirlpool Refrigerators
I have a GSS22IBMA GE side buy side. The fridge side works fine but the freezer will not freeze. Also it is hot around the the door frame of the freezer sometime quite hot.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 08, 2011 | GE Refrigerators
Side by side Admiral freezer freezes but fridge
check the damper vent door between the refrige and freezer and make sure its opening up to let cold air from freezer into the refrige,sometimes they freeze up and cant open and close when called upon to do so,if so deice it with a hair dryer,the side being hot is good telling you the compressor is operating correctly
Jul 28, 2010 | Admiral 26 cu. ft. Side-By-Side...
Not cooling in hot temps
Double check clearances around fridge, which should be zero on sides and top, as well as check baffle in stack, which should be 1-7/8" above burner. Also check door gaskets with paper (it should drag through when doors closed. Does the burner stay lit when on propane, even though temperature is increasing inside fridge?
Jun 01, 2010 | Dometic RM2852 Refrigerator
Does not hold temperature, warms up.
if you hauled on its side then it is very possible you have oil in evaporator. replace all sealed system parts. compressor, drier and evaporator.
Jun 21, 2009 | Roper Refrigerators
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My freezer is hot!
It is normal for the freezer or fridge walls to be hot sometimes, some important points are to make sure that there is enough ventillation around the fridge/freezer, especcially the back, so that air can circulate around it freely. Also maybe just check that there hasn't been anything fallen down the back blocking the vent, and that there isn't a dust collection or anything. Otherwise as far as I know this is normal.
Aug 19, 2008 | Frigidaire 16.7 cu. ft. / 473 liter...
My refrigerator is not getting cold
You should try to clean the coils under the fridge . Thats a simple thing to try .If your fridge /freezer cant remove the heat it wont cool ,also please make sure your doors are closing tight. We can start on all the free things you can try first..
Jul 11, 2008 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Not getting cool enough
try moveing the thormister up in the refer it is on the right hand side of refer inside refer box if this does not help use a fan and blow it tru outside vent on low
Jun 23, 2008 | Dometic NDR 1292 Refrigerator
Maytag side by side fridge.
My Maytag side by side is 7 years old. Bar between fridge and freezer just began getting very, very hot also? What can we do to repair? Does the condenser fan motor need to be replaced?
Oct 23, 2007 | Maytag MSD2656G Side by Side Refrigerator
Refrigerators Logo
101 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
