SOURCE: Phillips magnavox tv/vcr combo need codes to program remote
most universal remote controls will not operate the combo type units. Contact www.remotes.com for a repoacement remote.
SOURCE: Magnavox 42 LCD 42mf438b/f7 turns on/off by itself
Mine was doing the same thing. Update the firmware and it fixes the problem. Updating the firmware is done by downloading the file to a thumb-drive from the phillips product support page then plugging in the drive into the side of your television and turning it on. See your manual for slightly better instructions.
SOURCE: how do i get regular
Hello
I'm not sure about the model number of your TV, as here it is marked as both "27MS343S and 32MF338B/F7". Anyway I gies this solution as for the first denoted.
Insert antena to the antena socket at the back side of your TV marked as 75Ohms antena input.
[1] Press "Menu" button on the remote control handset to display menu on screen.
[2] Press "Vol+ or Vol--" button repetedly to hilight "TUN" [Tuner].
[3] Press "Ch+ or Ch--" button to hilight 'AUTOPROGRAM"
[4] Press "Vol+" to programming tv channels.
Tv will tune and store channels transmitted channels at that time, through entire bands, and will display the first channel receved after tuning process completed. It may take some minutes. You have to wait it to complete. After displaying the first channel, you can select your favourite channel Using CH+ or CH--" buttons. Ok.
SOURCE: how to hook up wii to a magnavox 32mf301b
You can connect the composite (Red white yellow) cables to corresponding connections on the back of the television. Then set channel to corresponding video input.
Testimonial: "thank you for your help, it got me thinking i used to use plug and play game on this tv. so i got my plug and play out and figured the green connector on the back was for the yellow plug on a game."
