Question about Polaris Pb4-60 Volute Polaris Booster Pump Part P5 P-5 Volute
What kind of a sealant should I use when putting back pb4 volute together. I saw that there was a red colored component around the pipe threads but couldn't identify what it was.
  • 634 Answers
Teflon tape will work fine just clean threads thoroughly with wife brush first
Posted on Jul 17, 2009
I have a 2006 yamaha vstar 650 classic I took the tops off to clean the injectors put it all back together but I have gas leaking from 1 of the 4 screws how can I stop it from leaking
Hi, Peggy you may have damaged a gasket or o-ring when removing the tops take it back off for inspection otherwise you can try some pipe thread sealant on the ***** threads for more information about your question and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
Carbs leaking Here is how to fix it
Carburetor Carb Leaking Gas How to Fix Repair it Motorcycle Honda DIY...
http://www.starmotorcycles.com/assets/service/manuals/2003/LIT-11626-16-05_22.pdf
http://s.productreview.com.au/products/manuals/32141_563ae9ef16ab5.pdf
Apr 10, 2016 | Yamaha Motorcycles
Polaris Pb4 - 60 Booster Pump volute thread size
It is 3/4 inch NPT (national pipe thread, as opposed to garden hose 3/4 inch thread.)
Jul 05, 2013 | Pool & Spa
Do I need thread sealant ie tape or other when attaching nitto fitting to outlet tap in order to seal the thread and prevent air leak?
One should always use sealant when making connections on any pipe/fitting with pressure (gas or liquid) inside. Teflon tape is a good all-round sealer--be sure to wind it around CW so that the outside fitting is trying to tighten the tape. Good luck!
Jan 05, 2011 | Garden
How do I remove the Inlet and Outlet PVC pipes attached to the Volute? They may be sealed with a sealant or glue and am not sure if I need to remove the Volute bolts first.
You just have to cut the pipes in a place where you can glue them back together with a coupeling. If you overheated the pump though you may have warped the pipes and will need to go back far enough to get to good pipe and replace it all the way up to the pump. They just screw into the pump and you can seal the new ones with silicone or teflon stick or tape. Don't use pipe dope as it is not good for plastic.
Nov 02, 2009 | Polaris Pb4-60 Volute Polaris Booster Pump...
Impeller does not spin freely
Pop off the half dollar sized cap at the back of the motor and use an adjustable wrench to hold the back of the shaft. They make a tool for this but with a little innovation an adjustable will do the job fine. When puting the impeller back don't tighten it more than hand tight and don't bump the motor on to seat it, this will overtighten it. You may have crossthreaded the impeller and will need to tap it out or replace it.
Jul 15, 2009 | Polaris Pb4-60 Volute Polaris Booster Pump...
I just replaced the motor bearing and after putting the whole thing together the water is pouring out of the front
Replace the mechaical seal and volute o-ring. Parts are available locally or try our website at www.arrowpools.net
Use the contact button and include your pump model number to receive a parts breakdown and pricing.
Jul 03, 2009 | Polaris Pb4 - 60 Booster Pump
Putting together pipes for natural gas to go through
if you want to make sure it doesnt leak use permatex black tar like pipe dope.you should not need this if threads are cut right and you are tightening to proper point
Feb 26, 2009 | Coleman Propane Forced Air Heater...
Seals are leaking on my PB4-60 pump
o.k. we will call impeller front ok ? take back cover off look at end of shaft slot for screw driver? put screw driver in slot turn impeller off .
Jan 22, 2009 | Polaris Pb460 Polaris Booster Pump...
Polaris Pb4-60 Volute Polaris Booster Pump Part P5 P-5 Volute Logo
139 people viewed this question
Top Polaris Garden Experts
Paul Bade
john h
Are you a Polaris Garden Expert? Answer questions, earn points and help others
