Question about UTStarcom Blitz Cell Phone
My phone only works when it's plugged into the charger
My phone only works when it's plugged in and keeps shutting off cause of low battery but the battery is charged
  • 403 Answers
New batteries are shipped partially charged. Before you start using your device, it is recommended that you charge the battery. Some batteries perform best after several full charge/discharge cycles. You can charge the battery in two ways: • Charging the device’s battery by connecting the power adapter. • Connecting your device to a PC via the provided Mini USB cable. Note: Only the AC adapter and USB cable provided with your device should be used to charge the device. Charging is indicated by a solid amber light on the left LED indicator. As the battery is being charged while the device’s power is on, a charging icon will be shown on the title bar of the Today screen. After the battery has been fully charged, the left LED becomes green and a full battery icon appears on the Today screen’s title bar. Warning! Do not remove the battery from the device while you are charging it using the AC or car adapter. As a safety precaution, the battery stops charging when it overheats. When the low-battery warning appears, do the following: • Immediately save your current data. • Synchronize with your PC or connect the power adapter to charge the battery. • Turn off your device.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Posted on Oct 06, 2009
5 Suggested Answers
SOURCE: my enV will not charge!
Hey i think i just figured out the problem to all the port charging issues for the envy and envy 2 phones with verizon. its not the phones, its the charger cord! the part that goes into the phone. it gets pulled out over time from pulling the cord out of the phone all the time. get a pair of pliers. grab the end and push the metal end of the cord against somthing hard, push it back in so it is at the appropriate depth. this should make it charge properly again!
Posted on Apr 06, 2009
Bajanguru
  • 7752 Answers
SOURCE: cell phone won't charge/or hold a charge
you are not to keep a phone charging that long...only charge a mobile when the battery is completely dead that is the only way that you will have a good battery for a long time.
what you should do is try a new battery with the work and see if that helps other then that you will need to have the phone usb port service or checked.
Posted on Jun 23, 2008
SOURCE: Motorola RAZR2 V9 new phone wont charge
Spare Battery Charger - Motorola RAZR V8 /V9 - $14.95
will need also a USA/Uk power adaptor /converter to use in Uk.100% works by charging battery separately from mobile
Posted on Apr 25, 2009
SOURCE: Battery will not charge
looks like the solution is pay a bloody fortune to lg to check if they can fix it or do what im doing and buying a desk top charger i have all ready bought a second battery so that way one can be in the phone while the other one is charging .they only cost about 10 dollars ill let you know how that goes
Posted on May 26, 2009
Why does my tom tom keep going the shut down page every 10 seconds I have pressed reset but makes no difference I ride bmw r1200rt
One possible cause is that your battery is low or the battery can no longer hold a (good) charge. In this case, the TomTom is shutting down because there's not enough battery to keep it running, even though it is plugged into a power source.
To determine if the battery is the cause, try to charge the TomTom battery .... using a (USB) connection to your computer, or a direct power source (i.e. while the TomTom is not being used). Let it charge for a few hours until the batter charge indicator shows that it is fully charged (or just leave it charging overnight).
Then, unplug the TomTom from the "charger" and power it up. If the TomTom (battery) doesn't hold a (good) charge, the device will shut down within a few minutes, e.g. 10 mins or much less.
When you (then) plug the device into a power source, and it doesn't stay on (i.e. it keeps shutting down after 10 seconds), you can safely conclude that the battery is the cause of your problem.
Apr 24, 2016 | Tomtom GPS
My motorola i1 (provided by boost/nextel) phone keeps shutting off & turning back on on its own. I have never dropped my phone nor got it wet. My battery is fully charged & it only shuts off &...
Try get another battery, it could be that the present battery you are using is malfunctioning, it could be bad and that could be the reason why it is shutting off and on, first, replace the battery to check the performance.
Jul 28, 2011 | Motorola Mobility i1 Smartphone
My g1 randomly shuts off...its charged..but won't
All you have to do is change the battery,in this case,battery don't have enough performance to save power and can not distribute current on the phone that's why it direct rely on the charger,when you see your battery is already deform its shape,expect low performance on your phone as well as easily got low battery level.
Jul 24, 2011 | HTC Cell Phones
Dropped phone in snow dried it out can charge bat. and it operates when plugged in.but when remove charger battery drops to low phone shuts off
Please try keeping the phone and the battery in a warm place for some time, then try to charge the battery and check if it works, also try battery from your friends battery from a similar phone, if it works, some problem with the battery and you would need to replace the battery.
Feb 28, 2010 | Cell Phones
My phone - dorado d800 -
This means that your cell phone would be shut down due to Low Battery.
Plug in the charger, wait for 15 minutes. Then try to ON the cell.
If that doesn't ON, either Charger or Battery is not working.
Change the charger and see if it works. If that works, perfect unless you need to get the battery changed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 18, 2009 | Cell Phones
Wont connect
replace battery
Mar 14, 2009 | Lands Phones
Motorola V3 keep shutting down
Try a new battery if that does not work then you should take the phone and have the firmware flash to correct this error.....take the phone to a mobile service center to have this done.
Oct 25, 2008 | Motorola Mobility RAZR V3
HTC S620 shuts down while I am on a call
Got a new battery & the phone works as good as new now.. Guess it really was the battery
Apr 28, 2008 | HTC S620 Smartphone
Phone shut off
Plug it into your walloutlet usb charger rather then the one connected to your pc. once your battery is so low it wont even have enough juice to show the charge battery screen if your chargeing through the low voltage pc active sync cable.
Feb 11, 2008 | Motorola Mobility Moto Q
LG vx8300 phone will not turn on
dunno. try to have it on the charger, and at the same time try to push and hold the power button. try it a couple times. my v180 from motorola did that and it seemed to work.
Sep 18, 2007 | LG VX8300 Cellular Phone
UTStarcom Blitz Cell Phone Logo
2,650 people viewed this question
Top UTStarcom Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
