Question about Electronics - Others
A CD was recorded on a Philips digital CD-R recorder and may not have been finalized correctly. It reads as blank. How can I salvage the recorded data?
  • djbunn Jul 14, 2009
    I tried to finalize the CD thinking it was not finalized, but it would not finalize and read disk error.
    President:
  • 1,124 Answers
It would need to be finalized..
That is the only way at this point..
Hope this helps !!
Posted on Jul 14, 2009
I have a Philips 615 DVD recorder that has worked wonderfully since I got it in 2005. However, this weekend it decided to stop reading any DVD put into the tray. I was recording something and finalized it....
Sometimes a blank DVD will not be the proper format. Upgrades have been done to DVD-R disks, and your recorder might not recognize the upgraded format on the newer disks. This has happened with Philips, Emerson machines- they all use a Funai burner. I have found with my FUNAI/Philips/Emerson recorder that purchasing the Philips, 1-16 speed DVD-R blank disks fixes this problem on my 2 machines. If you have an older DVD-RW 2 speed disk, it should work as well.
Jul 01, 2017 | Televison & Video
Recording
The No OPC message means that the unit can't record. The laser power calibration for the burner failed the internal test with that disc. Was the disc a blank disc? Make sure that you use a clean CD-R or unfinalized CD-RW. Try a different lot or brand of CD-Rs or CD-RWs. If the problem persists, then the laser on the recorder is damaged. If the unit is under warranty, contact Philips. However, based on the date given on the manual, this may not be worth finding a shop to fix the unit. DVD/CD burners for computers are fairly cheap but I'm not sure of the specs for a replacement CD burner for inside this unit.
The manual is available from Philips here: www.p4c.philips.com/files/c/cdr765bk/cdr765bk_dfu_eng.pdf . The trouble-shooting information is on page 21 (page 23 of the PDF).
I hope this helps.
Jul 11, 2013 | Philips CDR765 2-Disc CD Recorder
How do you record
You put blank media in the record side and hit the record button. These CD recorders are not as easy as using a Cassette deck. You need to Finalize the disc before it can be read on a standard CD player.
Dec 15, 2012 | Philips CDR765 2-Disc CD Recorder
My 760 recorder keeps show no audio when I try to record. I've tried hooking it up serval ways no luck. However it plays perfect.
You can not use normal Data CDs. Use CD-R Digital Audio CDs or CD-R Audio recordable CDs. If you use correct Digital Audio Recordable CDs, it will show OPC. Once you press Recording, audio out is coming. Otherwise you can not listing to audio. Please read manual carefully. Above will solve your matter.
From Channa
May 10, 2011 | Philips CDR760 CD Player
Hi.I have CD Recorder Marantz DR6000.After reading and initalizing blank CD-R Audio next on display show OPC ERROR.It,s reading all audio CD,s,oryginal,and CD-R.When I wanna finalized old CD-R,recorded by...
DR-6000 only accepts CD-R audio or CD-R music discs, not the standard CD-R discs. the difference is that the audio and music discs have the OPC formatted differently and they cost a bit more because they include the royalties fee. Standard CD-R discs won't work in this recorder. The correct discs have compact disc "digital audio" logo on them.
Oct 01, 2010 | Marantz DR-6000 CD Player
Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Mar 30, 2010 | Philips CDR775 2-Disc CD Recorder
My cd recorder wont read blank cds help me please
Do as it asks, insert blank CD-Audio or CD-Music media.
Discs for recording
For recording, make sure to use special audio discs only.
These discs are marked with “Digital Audio” and the logos shown below.
There are two different types of audio discs for the use on this CD recorder:
– CD-Audio Recordable (CDR) discs
These discs can be recorded on once and
play in all standard CD players and CD
recorders, when they are finalized.
– CD-Audio ReWritable (CDRW) discs
These discs can be recorded on, erased and
re-recorded many times and play in CDRW
compatible CD players and CD recorders,
– All Philips CD players and CD recorders
with the sticker shown here are CDRW
compatible.
To ensure proper working of the set we recommend the use of Philips audio CDR and audio CDRW discs only.
Note: Do not use a computer CDR or CDRW as recording will not work!
Go here and download the manual. You'll need it.
http://www.p4c.philips.com/files/c/cdr602_00s/cdr602_00s_dfu_eng.pdf
Mar 04, 2010 | Philips CDR602 CD Recorder
Hello i have a Philips cdr 870. With every blank CD inserted, the display shows NO AUDIO. Pre recorded CDs play OK. Unable to record. I have recently aquired this machine and this is the first time I have...
You are probably inserting blank computer discs, eg 650 or 700mb rather than blank music CD-R or CD RW`s which this machine is designed to work with. The correct discs are labelled "music audio" or 80 minutes. You can only use these types of discs. Why? When these recorders first came out, it was a way of battling piracey in copying discs. I believe there is a "hack" to enable this player to use blank computer discs.
SMA
Jan 13, 2010 | Philips CDR870 CD Recorder
Wrond Disc
The disc you need to use to record is "PHILIPS CDR MUSIC". That is what it should day on the top of the disc. On the left side of the disc, it should say "DIGITAL AUDIO RECORDABLE". I spent a lot of money buying the wrong discs before finally finding the correct one. So I know your frustration!
Apr 05, 2008 | Philips CDR600 CD Recorder
Electronics - Others Logo
48 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
