Question about Microsoft Video Game Consoles & Games
Red flashing light on bottom right on 360 elite (e73 error)
I was playing call of duty on my x box 360 elite and the screen went fuzzy so i restarted it and i had 1 flashing red light on the bottom right when i restarted it and i had an e73 error on the tv screen . how do i fix it?
  • 90 Answers
X-clamp Fix. Also make sure you have all four heat patches attached to your memory chips. If you don't have any buy some. They sell them on the net.
Posted on Jul 21, 2009
Xbox-360 elite lower right hand red flashing led light code error E73
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 17, 2011 | Microsoft Xbox 360 Console
Xbox 360 Console: one red light code E73 appears on screen...
your xbox is going to die..
but there is a way that you can play it.just heat up your xbox for couple of mins.then try works.
every time you see E73 error just do this
for more help email me how to do.
May 17, 2010 | Microsoft Xbox 360 Console
Xbox 360 E73 error. What do I do?
Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
Apr 07, 2010 | Microsoft Xbox 360 Console
Xbox 1 flashing red light and e73 system error
e73 is an input/output error. Hopefully you are still under warranty. Contact Microsoft at Toll free: (800) 4MY-XBOX or (800) 469-9269. If you are outside of your warranty period, I believe they will still repair it for $99
Feb 21, 2010 | Microsoft Xbox 360 Arcade
One red light on elite
Extended MS does not cover E73, so they won't fix for free :-(
The E73 error though is the NIC error (network), so usually shows a problem with the internet connection port, but can also be a problem with the motherboard. I have fixed the E73 issue in x360 units before, but that tends to be an error that's a real pain to sort.
Even once fixed, it usually comes back, it's really unlike any other E code error in that respect. Your cheapest option is just to get an HDMI white base unit on eBay (with no cables or anything) then just swap the white case for your black one, then sell yours on for spare parts.
Hope this helps.
Jan 01, 2010 | Microsoft Xbox 360 Elite Console
E73 Error
Error E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
This error is also caused by a cold solder joint under the Southbridge or the Ethernet chip.Can also be one of the solder joints that lead to the GPU.
check if you are getting any flashing red lights on your xbox 360 power up button, if you are not getting any flashing lights the probably you may try unplugging any Ethernet cable attached if you had tried connecting to Xbox Live and at that time you face this error, re-connect and check
If you still get this problem and you see a single flashing red light on your console, please send your console for repair to MS support if it is under warranty
Dec 24, 2009 | Microsoft Xbox 360 Console
My xbox 360 has shown up one red flashing light and E73
HI. This is an Ethernet port issue.
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port. Try using a new Ethernet cord. If the error continues after the new cord is used, contact Microsoft for a repair ticket. the port will need to be replaced. (Internal connection failure)
Possible solder break
Oct 13, 2009 | Microsoft Video Game Consoles & Games
Xbox 360. problem code E73 . playing call of duty 5 when the screen went greeen and lines went down the sreen like an atari or something. a red cirle appeared around the power button, when i turned my xbox...
the problem with e73 is that its the system telling you there is a problem with the ethernet cable reciver but there may or may not be. 90% of the ,consoles i come across have not been a problem with the ethernet reciver at all some of the more popular problem flashing this code is a result of system failure in the mother boards ability to read properly the connection between the cpu and gpu units under the heat sinks. there are a few fixes avalible for this projected e73 problem. i strongly caution you not to preform work unless you are familiar with the console and its internal parts. ------- I cannot guarantee that this will work for everyone to fix it.
Remove the A/V cord from the back of the XBox 360. Stick two sticks into the fans to prevent them from spinning. This will cause the system to overheat within five minutes. You will know its done when the first and third quadrants light up red on the system (indicating the system has overheated). Unplug the system, plug it back in and turn it on to see if it was successful. (Note: While this method does not void your warranty, if your XBox is still under warranty I suggest sending to Microsoft to fix.)
Sep 11, 2009 | Microsoft Xbox 360 Console
The screen went all fuzzy and diferent colors so i turned it of to re start it and the red light in the bottom right corner lite up. how do i fix it? what is the problem? the code is e74 it is an x box 360
That is a system error that effects the video on the xbox. It's a pretty common error. The best thing is to contact microsoft at 1-800-4MYXBOX, (I think that's the number but you might want to check at and have it sent in to the repair shop.
Jun 22, 2009 | Microsoft Xbox 360 Elite Console
One red light bottom right hand corner
You can check out the informative blog post at
This post describes the E74 error with one red light problem.
hope it helps...
Jul 22, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
73 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
