Question about Sony Cyber-shot DSC-W55 Digital Camera
Set date and time comes up every time i turn on camera
Have had camera long enough for one battery charge to be used up. when battery was low, the set date and time board came up every time i turned it on. i recharged battery, reset date and time and it still has same problem. when i initally bought camera and set it up, it worked fine.
  • 2,985 Answers
Re: set date and time comes up every time i turn on...
The date time is controlled by another 'button' type battery in the camera- like a watch battery, there 'go' in time.
This is not a 'user' fixable item usually because it mean dismantliing the camera.
Sending away will be pricey- well on the way to the price of a new camera
So just live with it - I would
Posted on Nov 17, 2007
0 characters
3 Points
Camera turns off itself
This is likely because:
  1. You are using the wrong types of batteries (Alkaline, Ni-Cd or Ni-MH batteries are recommended for digital cameras) NOTE: don't mix different types.
  2. The battery is out of charging cycles and won't retain charge. (Most rechargeable batteries can be charged only about 1000 times after which they won't hold charge)
  3. The batteries aren't 'powerful' enough. (low quality rechargeable batteries with low capacity shouldn't be used on digital cameras, Always buy batteries specialized for cameras (from camera stores or studios))
  4. The wrong battery type is selected in the camera's settings. (Most cameras let you select the type of battery you are using from it's settings. Browse through the settings and see if this is the problem)
Hope that fixed it. Good luck.
Apr 28, 2011 | Nikon COOLPIX L4 Digital Camera
I have to reset date time etc everytime i turn camera on
If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
1. Confirm that the camera power is turned off.
2. Slide the memory card slot / battery cover lock and open the cover.
3. Hook your nail onto the date battery holder and lightly pull up.
4. Remove the battery holder in the direction indicated by the arrow. a570isbackupbatremove.gif 5. Remove the battery by pulling it up in the direction indicated by the arrow.
a570isbackupbat.gif 6. Insert a new battery with the (-) side facing up.
7. Replace the battery holder and close the memory card slot / battery cover.
8. When the Date/Time menu appears set the date and time.
Feb 05, 2011 | Canon PowerShot A590 IS Digital Camera
My wife is complaining that every time she turns off/on the camera she has to reset the data/time. I understand that when the batteries are changed the settings may be lost, but not simply when the camera...
Sounds to me that there may be another battery inside the camera that is going bad.
Issue: Everytime I power on the camera the Date / Time needs to be set.
Solution: Replacing the Date Battery for the PowerShot A480.
Replacing the Date Battery. If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
Please note that the first date battery may appear to expire relatively quickly after you purchase the camera. This is because it is installed in the camera at the point of manufacture, not when you make the purchase. caution.gifBe particularly careful to keep the date batteries out of the reach of children. Seek medical assistance immediately if a child swallows a battery since corrosive battery fluids can damage the stomach or intestinal walls. 1. Confirm that the camera power is turned off.
2. Open up the battery door / cover and remove the AA Batteries.
3. Remove the date/time battery holder.
4. Grasp the battery and slide it in the direction of the arrow.
a480backupbatt.jpg 5. Insert a new battery with the (+) side facing up.
6. Replace the battery holder and battery cover.
7. When the Date/Time menu appears set the date and time.
note.gif After purchasing the camera and turning on the power for the first time, although the Date/Time menu will appear, you do not need to replace the date battery. If you ever dispose of your camera, first remove the date battery for recycling according to the recycling system of your area.
Dec 31, 2010 | Canon PowerShot A480 Digital Camera
I have to reset the country date time etc every time i turn my camera on, i have tried going through menu and reset but this hasn't solved the problem. Please help
There is a built in battery that can keep the time date etc. info for 20 something hrs. without any other source of power. If your camera has a charged battery, is plugged into an active USB or powered by an adapter and you shut it off and then immediately turn it back on again, what happens? If the clock needs to be reset are you sure that you have completed setting the time. After adjusting all the settings you hit set. Most likely it seems that your internal battery is bad. It should charge when the camera is being powered by the main battery.When you say every time you turn it on I'm not sure what that means. If you turn the camera off and remove the battery for more then 30 hrs. it will have to be reset. If that is the case you need to leave a fully charged battery in long enough to charge the built in battery. If the built in battery is bad you will need to find out if it can be replaced.
Aug 04, 2010 | Casio Exilim EX-Z750 Digital Camera
Camera keeps loosing the time and date settings. When turning the camera on the lens does not open, then a screen asking to set the date and time settings appears - once date reset the camera works...
have you check the settings for time and date have you saved it? You can also try to remove the cam battry for 2 mins. then put it back in then turn on the camera and then after few secs. turn it off, then see if the issue persist.
Feb 21, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
The date will not stay set. Every time we turn the camera on it opens with the date screen. We set the date and it then goes into shoot mode but the date is not set. All pictures are stamped with the...
to keep the date on, you have to leave the camera off with a charged battery for 24 hous to charge the inner battery that keeps date on. If this doesn´t solve the problem then is because the inner battery won´t charge anymore, but it will take pictures as normal without the date. To avoid this don´t leave the camera too long without use or with a worn battery.
Oct 04, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Sony DSC-W150 power on keeps going to set date/time
The date and time settings are displayed after turning on the camera. Solution
sp.gif sp.gif It is normal for the camera to lose time and date settings if the internal battery is left uncharged for an extended period of time; some cameras will default to the time-setting screen when turned on if this happens. Follow the steps below to resolve this issue.
  1. Turn off the camera.
  2. Do one of the following:
    • Insert a fully-charged battery pack into the camera.
    • If the camera is supplied with an AC power adapter, plug the adapter into a working electrical outlet and then connect it to the camera.
  3. Allow the internal battery that retains the time and date information to charge for at least 90 minutes.
  4. After enough time has elapsed to sufficiently charge the internal battery, turn on the camera.
  5. Set the time and date.
  6. Turn off the camera for 30 seconds.
  7. Turn on the camera again.
  8. Check to see if the date and time have been saved.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. The Sony® eService Web site at can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Dec 23, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Try resetting your camera. In picture taking mode press menu. Go to setup, go up to reset, press right arrow, make sure reset is highlighted and press set.
Then TAKE OUT MEMORY CARD. Go back into menu, go to setup, go up to format, press right arrow and highlight format, press set. Input ur date and time again and then power off and back on. If that doesn't help then you have to send into repairs. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
Feb 11, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
85 people viewed this question
Top Sony Digital Cameras Experts
Larry Spears
Larry Spears
Vish Iyer
Vish Iyer
Rick Johnson
Rick Johnson
Are you a Sony Digital Camera Expert? Answer questions, earn points and help others
