Question about Refrigerators
Terrible Plastic After-Tast in Dispensed Water (Refrig)
I have a GE Profile PSC25MSWA SS refrigerator, just 1 year old. However, after waiting 3-4 months before changing the filter or using the water dispenser; I finally changed it and even after multiple times of using the dispenser, the taste of plastic resides in the water. I was wondering if this is due to any water becoming stagnant in the water lines? Not sure if my lines are plastic or not, but per reading online articles, it could be. Would this occur? How do I rid of the horrible taste. I would like to enjoy free water again.
    Champion:
  • 363 Answers
If indeed it is stagnant water you have to find the water source tap off of your water supply. Then trace out the routing of the feed water line to your refrigerator. Turn off the tap, remove the line at both ends. You can abandon the existing line. Reroute the new line. or you can remove the old line and follow the same route. Reconnect the tap and refrigerator ends.
Posted on Jul 22, 2009
Ge profile troubleshooting
There may be a blocked drain. Some of these refrigerators had a loop of the cooling tubing back there and when the refrigerator shuts ofrf this water will drain off. It is supposed to drain out a channel and tuvbe but if this is plugged it runs out the front.
Jul 30, 2014 | GE Refrigerators
A GE Profile Model, double door refrigerator with a water leak
If the leak is on the refrig water valve where the wall water line connects to , then use a 1/2" wrench and tighten the fitting on the water valve itself . If the leak is on the plastic tubing at the bottom of the refrig water valve , pull up on the small white ring while pushing down on the plastic tube to remove it from the valve . Cut off about 1 " of the tubing and reinsert it into the valve with pretty good pressure to be sure it is inserted completely .
Mar 27, 2010 | GE Refrigerators
GE Refig. water does't dispense
adjust tempt of fresh food side it may be to cold and freezing veg/ and water line .. **** ..
Jan 19, 2010 | GE GSH25KGMWW Side by Side Refrigerator
Our GE Profile Arctica will not make ice cubes.
You have 2 problems .
1 . the water valve is not letting enough water in . Pt # WR57X10032 . This is located on the back of the refrig , where the wall water line connects to , on the refrig .
2 . The dispensor flap door , is not closing completely , to seal off the warm outside air , thereby , causing frost on the inside dispensor area , and , on the bottom of the ice dispensor bucket . The usual cause , is the door flap solenoid , pt # WR62X10055 . The plunger , which comes with the solenoid , usually rusts , causing the flap not to close completely .
Dec 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Smelly water dispensed from ge profile refrigerator
flush the water tank put a glass press for water and keep flushing on till smell gone
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Not keeping cold temperature and can smell plastic from heat
Sounds like the condenser fan motor is either jammed or has failed. if you wil pull the refrig from the wall and remove the lower compartment cover you will see the fan I'm reffering to as well as the condenser coil and compressor. if the fan has failed you can put a house fan blowing into this compartment to keep the unit operational until you can get it repaired. thanks for using FixYa Peyton
Feb 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water filter
are you looking for a replacement filter for your refrig or looking to locate its whereabouts in refrig???? 11 years ago its possible, sorry very probable that a water filter did not come equipped with refrigs.if so it would be in top right corner mounted on ceiling insider refrig.
Mar 11, 2008 | GE Profile TPX24PBDCC Side by Side...
Water freezing at bottom of refrigerator/Temperature not right
thats a water tank holding water dfor the dispensor, if everything in refrig is freezing quite possible that the water in tank froze as well, which would explain no water,
Feb 24, 2008 | GE PSS26NSWSS Profile 25.5 Cu. Ft....
Refrigerators Logo
179 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
